lads, i have removed the flywheel on my silvertop zetec but.........
do thay have a bolt pattern that only allows them to bolt on one way or not???????? ie in referance to TDC
i have managed to get a 1.8 flywheel but b had already took the 2.0 one off
i'm stressing...........
Will only go on in one position.
jesus thank goodness for that cheers thats a real relief!!!!
onward n upwards tomorrow with the budget zetec project
Agreed, but not sure why, as in what's the point of it being keyed?
[Edited on 18/3/12 by ChrisL]
So that the ECU see's the crankshaft position correctly
Ahh of course!!
Chris
Quote :-
'And its all done by the bolt /hole spacing. There will be only one position where ALL the bolts will go in easily without ANY
interference.'
How much interference will there be?
Could anyone get the bolts in if they tried hard enough - without resorting to drills, files etc.
Len.
Originally posted by avagolen
Quote :-
'And its all done by the bolt /hole spacing. There will be only one position where ALL the bolts will go in easily without ANY interference.'
Len.
Thanks for the encouragement,
I only ask as one of mine was tighter than the others.
It must have been a dirty thread.
Len.
a woodruff key or other type of keyway could'nt or should be used on a flywheel as its a high load item for short periods ie starting he car
keyways/woodruff keys do where & can work loose which usually scrappd the componant
i did think it was a non symetrical bolt pattern its not instantly noticable on a zetec flywheel that it is'nt symetrical
time to fidde this weekend to see if ican get the cheapo motor up & running aslong as i can get hold of a starter motor i'm good to go
