Hi guys, looking for advice on who you recommend for Sierra 7" diff rebuilds? Need a 3.38 swapped into a 3.62 Lsd i already have. Your feedback
would be appreciated ie, your good/ bad experiences in the past on this subject. I know its not going to be cheap but want to fit and forget. also
forgot!! For a hayabussa powered car is it work servicing or uprating the std viscious Lsd? There all getting on a bit in the years now but they maybe
last forever do they? Car used on road & trackdays.
Thanks in advance for your help.
Ronnie
[Edited on 17/2/16 by Zetecron]
http://www.daveraemotorsport.com/
I've not used him but my m8 zx12rdug off here has and had really good service doing exactly the same swap as you are
Call Andy at the Scottish Kit Car Center, he did a mine installing a ATB diff into my 3.14. Good service.
http://www.scottishkitcarcentre.com/
Why don't you unbolt the lsd from the 3.62 and bolt it into the 3.38 i did that with my 3.14, you only then need to adjust the backlash
Road and Race transmissions in Kent did some diff work for me
Good service
I've not used him but my m8 zx12rdug off here has and had really good service doing exactly the same swap as you are![]()
