tony@signtek.net
| posted on 15/12/10 at 07:26 PM |
r1 fuel pump help
Hello
fuel injected 5PW R1 2002
I know this sounds a bit dumb but can anyone tell me where to put the fuel pump for my haynes roadster BEC?
And anything else i should know when sorting this out
I understand that i have to run a fuel return line to the tank is that right?
jimgiblett
| posted on 15/12/10 at 07:33 PM |
Link it up
Fuel Tank out > low pressure filter > pump inlet > high pressure filter > fuel rail > regulator (at the end of the fuel rail) >
tank
Hope this helps
- Jim
tony@signtek.net
| posted on 15/12/10 at 07:42 PM |
Any suggestions on where tto get filters?
Thankyou
jimgiblett
| posted on 15/12/10 at 07:52 PM |
I used an 10mm glass low pressure filter from ebay similar to
http://stores.channeladvisor.com/customizedchoppers/items/item.aspx?itemid=1140369
and a Ford Focus 1.6 petrol high pressure one from Halfrauds
- Jim
speed8
| posted on 16/12/10 at 09:42 AM |
I used the original 5PW pump on mine. Mounted it to the bottom of the tank. Seem fine and already has the required inlets outlets.
Chaddy
| posted on 16/12/10 at 10:42 AM |
I have also used the original pump and it runs fine.
jimgiblett
| posted on 16/12/10 at 01:36 PM |
I would use either the original bike pump if you have it and you havent had your tank made yet, or a universal bosch 3 bar pump.
IIRC mine is this one:-
http://www.fuelpumpsonline.co.uk/bosch-fuel-pump-0580464070-192-p.asp
- Jim
adithorp
| posted on 16/12/10 at 02:05 PM |
Mine's as Jim describes using a Bosch in-line pump and a 2lt Astra filter.
If using an in-line pump mount it as low as possible either below or level with the bottomof the tank, so the feed in is gravity fed. They don't
like to suck the fuel (tends to cavitate and create bubbles) as it would have to with the pump mounted higher.
adrian
http://jpsc.org.uk/forum/
tony@signtek.net
| posted on 18/12/10 at 12:42 AM |
Have got a 5pw pump but not sure how where or to fix it!!
There are no fixing holes in the pump so i guess i may need a fixing flange to push down on the gasket or something
I presume it goes inside the tank although it has wiring on it which is a worrying
There are two inlet/outlets on top (not sure which is which) or is one a breather?
does the fuel return just drop in to the filler neck?
A photo of one fitted to a tank would be great or advice from someone who knows i would appreciate
speed8
| posted on 22/12/10 at 05:01 PM |
Just to close this one out for you
Here's a couple of pics. These are looking from the back of the car. The pump mounts externally on the underside of the fuel tank. I've
got a hole that the pump goes into with a thicker mounting plate section to bolt the pump to so that the bolts don't penetrate all the way
through.
The silver hose is the return feed from the engine, The black one with the Yamaha clip is the outlet. The connector is the pump 12V supply from the
ECU. The unused connector is the fuel level indicator. Basically it tells you when it is low as the bike didn't have a graduated level. No point
wiring it up as I'm led to believe that it goes through some electrotrckery in the bike dashboard to turn on the light.
I'll probably fit a plate on the car to protect the pump and hoses but for the time being it should be fine.
Hope that helps a little.
