Poll: Haynes Cost Vs Other Kit Options [View Results]
Haynes Roadster
Westfield
Other
<<  1    2  >>
Author: Subject: Haynes Cost Vs Other Kit Options
Padstar
posted on 15/7/12 at 10:56 AM Reply With Quote
Ok so maybe the engine and transition could be an easier option as they would be relatively straightforward to change post registration.
Would the engine plus gearbox cut it as I had planned on upgrading the diff to a newer model as my donor has the older viscous diff which I have been told is not that great?
chillis
posted on 15/7/12 at 12:40 PM Reply With Quote
Originally posted by Padstar
3k all in - wow. I have always had the idea of new parts giving a new plate but thought the £ would prevent it. Are u only allowed 1 refurbished part?
Surely the engine, gearbox, breaks and springs would eat a long way into 3k if purchased new??
For a new reg. you must use all new parts except for one which must be fully recond. and all recepts to prove.
The cost of the new parts is the killer and a westfield would be the best route here.
Build a haynes using a used donor will be much cheaper. though you would have to be lucky to do it for 3k, I guess you'd have to make absolutly everything. AshG's build cost of 6k seems more realistic especially if you buy in the bodywork. Not sure who's still doing bodywork for the haynes though as Saturn/NTS have stopped.
Have you considered the MEV exocet?
[Edited on 15/7/12 by chillis]
britishtrident
posted on 15/7/12 at 12:49 PM Reply With Quote
The best financial option by far is to buy something somebody else has already built (by that I mean a Westie or an MK) just make sure you buy the best you can find.
[/I]
Padstar
posted on 15/7/12 at 05:53 PM Reply With Quote
If I changed the dif for a later model would it be blatant and picked up easily by the inspectors? Even if I kept with a MX5 model. Do they have the vin on the dif
<<  1    2  >>
