Mark100
posted on 3/10/14 at 09:59 PM |
tank wont fit
ive had a tank made to book sizes but it wont drop in from the top
and I had it baffled and a swirl pot in the bottom
so now it wont slide in form the side
or am I just missing something realy easy
Simon
posted on 3/10/14 at 10:26 PM |
Bit of a boo boo on the measuring then. I'd suggest removing the verticals that keep top rail in situ, fit the tank and weld uprights back
in.
Simon
skov
posted on 4/10/14 at 06:49 AM |
Not sure what dimensions mine was made to, but fitting from the top involved a mallet and lots of swearing!
daniel mason
posted on 4/10/14 at 10:22 AM |
What does it sit on at the bottom?
Usually just a couple of small sections. Maybe easier to make them remove able and fit tank from under side!
Ben_Copeland
posted on 4/10/14 at 06:53 PM |
Mine had to go in from the back. Fitted before the back panel went on. Have to fit between my cage legs and chassis rear frame
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Mark100
posted on 4/10/14 at 08:52 PM |
looks like im cutting the rear uprights out and making them removeable (bolt back in after the tanks in ) that should give the biggest open area might
add a couple of extra wider than the tank wile im at it
