Piooly
| posted on 29/5/15 at 03:12 PM |
Falcon RV8 (haynes Roadster Finally finished)
Well its taken me a year and a half of weekends and evenings to build the car from start to finish. I have done everything myself, all fabrication
from rollcage, bodywork fibreglass vents to painting etc and as its my first go I am chuffed with the results!
Got my test on Monday 8th June so please let me know if I have any areas for concern. Cant wait to get it on the road and see whats its really like.
Weight distribution is dead on 50/50 which was a complete stroke of luck! (not posted photos before so hope this works)
Spec is :
-Rover V8
-65 litre fuel take
-Adjustable coilovers
-Rose joint adjustable wishbones (on outer joints only)
-Hi Spec 4 pots front and 2 pots rear
-Race Tech Dash
-R888's
sprouts-car
| posted on 29/5/15 at 03:19 PM |
Wow thats stunning.
I love the bulge on the bulge look.
Build blog
Ugg10
| posted on 29/5/15 at 03:22 PM |
Excellent job, love the retro 70's custom feel to the car (IMO).
Only comment I would say is to get a noise meter app for your mobile phone and check the db levels against the IVA manual method and pass marks (tick
over and IIRC half stated max revs, or used to be for SVA), those exhaust do not look like they have much sound deadening in them.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Piooly
| posted on 29/5/15 at 03:28 PM |
I bought a proper sound meter years back for track days. First time I tested once the car could be fired up at tickover I was 99db @ 1100rpm. So
obviously that was not going to do, put some DB killers into the mufflers and this came down to 90db, then I have modified the db killers so need to
test again now, but hoping its shaved a bit off........ Its going to be my most difficult area to pass I think..
CosKev3
| posted on 29/5/15 at 04:02 PM |
Looks mint, well done
Have you made the dash/tunnel top etc?
One thing that should fail(although one passed on here not long ago with similar ) is the side repeators on the mirrors, have a look at the angles of
rear visibilty in IVA manual.
Piooly
| posted on 29/5/15 at 04:43 PM |
Yes I made the dash and tunnel. Used a block of modelling foam to form it and then glad in fibreglass, then cushioning and carbon fibre upholstery.
Do you mean using them as front indicators because the headlights also have a ring of forward facing LED indicator lights built in.
CosKev3
posted on 29/5/15 at 06:36 PM |
Excellent job on the panels you've made fairdos!
The car needs side repeators, and they need to be visible from the rear of the car.The ones on your mirrors are not visible from the rear at all.
pretty sure they need to be visible from 5 to 45 degrees from standing at the rear of the car.
[Edited on 29/5/15 by CosKev3]
Xtreme Kermit
| posted on 29/5/15 at 07:29 PM |
Nice look! Loving it
Irony
| posted on 29/5/15 at 07:34 PM |
Looks sweet mate, very mean looking. Hats off to you, looks like a quailty job. Your exhausts must be loud as mine are loud with 5 inch silencers!
I would be interested to know what dB killers you are using. I am applying for the iva now.
Check the radiuses on your exhaust tips. They should be rolled edges for iva.
sdh2903
| posted on 29/5/15 at 07:49 PM |
Stunning
Massively impressed you've scratch built that in 18 months. Good luck with IVA and let us know how you get on.
big_wasa
| posted on 29/5/15 at 08:11 PM |
Where is the engine bay shot ? Very nice job.
garyt
| posted on 29/5/15 at 08:28 PM |
I really like it , a really nice job and good luck with the iva
remember we are not mad just creatively insane !!!!!
Chris_Xtreme
| posted on 29/5/15 at 09:42 PM |
loving it - agree re the side repeaters and also the need for an engine bay shot!!! like the idea of the double scoop need to see what is under
there being a rv8 fanboy myself!
dubzter
looking good, loving the nose cone, is that your own work with the vent or is it an off the shelf item?
_______________________
Blog
Facebook Build Thread
Haynes Forum Build Thread
Locost Builders Build Thread
Piooly
| posted on 30/5/15 at 01:07 PM |
Nose cone is a gillham one bu i have added the vent in the top. Took some making but caterham did some tests and found the nose cone vent allone
increased downforce by 50 percent!!!!
Engine photo to follow when i am back at work on monday. Its the best looking part on the car! )
Think i will fit some side repeaters in that case. Would not want to fail just cause of that...
CosKev3
| posted on 30/5/15 at 01:16 PM |
Have you had a look at the IVA manual?
The angles of visibilty are pretty severe to the rear, you can either fit to the outside of front or rear arches or probably on yours you might get
away with them on front legs of the rollcage.
loggyboy
| posted on 30/5/15 at 08:33 PM |
Menacing look. Love it!
With regards to repeaters, its 5 degrees from rear, so very important to add some repeaters else where, higher than rear arches. Also make sure you
blank the ones left on the mirror as you are only allowes 1 set of repeaters.
Mistral Motorsport
Piooly
| posted on 1/6/15 at 11:47 AM |
Ok so have ordered some small side repeaters to add to the front arches. I will leave the mirror indicators wired up for now and if the tester wont
allow it I can disconnect on the day I guess..
As for exhaust tips, I was going to rotate these so that they face the floor. They should be fine for the radius then and hopefully it will drown out
a couple of decibels...
trying to post a a photo of the engine but everytime I try it just shows somebody elses photo instead of mine.. not sure why..
loggyboy
| posted on 1/6/15 at 12:01 PM |
Tester might want to be sure they cant be simply reconnected. I would consider disconnecting and putting some black vinyl over the lens, then
reinstating post IVA.
I have had a similar issues with images before, try posting the URL link rather than the PG shortcut.
Mistral Motorsport
Irony
| posted on 1/6/15 at 12:23 PM |
Last year at a mates IVA I suggested this to a Friendly IVA Tester and he said you could try it and he would accept it for the noise test but he
doubted it would make much difference to the noise test on a twin exhaust setup as the ground will reflect the noise and the noise from the opposite
exhaust will add to the noise tested. The tester was very accommodating for the noise test and even took the car to the far end of the car park to
test were sound couldn't reflect. If your very lucky the tester might let you rotate both exhausts away from the microphone after the radius
tests have been done.
Piooly
| posted on 1/6/15 at 01:24 PM |
interesting thought. I shall do a few tests this week with my DB meter to see what happens...
As for tapeing up the mirror indicators, its probably a good idea to do this before hand. No point giving the tester anything to cast concerns on
ehhh....
Irony
| posted on 1/6/15 at 01:36 PM |
Please could post up the results as this may help me with my IVA.
Piooly
| posted on 15/7/15 at 04:47 PM |
Ok so had my test first week of June.
Examiner loved the car but it failed. Went with the intention of a fail so was not too dis heartened.
Fails were -
- Noise, 105db !!!! (had to fit a second silencer which is also perfect for trackday noise regs)
- Couple of radius issues, stereo, headlight bracket, passenger dash edge
- Hose standoffs needed on where my brake lines where they zip tie to the wishbones
So very minor stuff really. He said as soon as I started it to get it off the trailer he knew it was going to fail on that but he thought he would not
say till the end of the test.....
Took car back at the start of June and now its passed!!!!! Just wanting on my V5 documents etc from the DVLA. They have a 2 week backlog so they
should look to process my on Monday 20th July, so fingers crossed I don't have any problems there.
Overall chuffed with the car and if I went for anther IVA test I am sure it would pass first time now I understand the rules a little better.
Youtube video link to follow soon!.
