alex89
| posted on 6/11/13 at 06:29 AM |
thank's a lot.
I am also lucky because she leaves me hours in the garage, she is very tolerant.
alex89
| posted on 9/11/13 at 02:54 PM |
manufacturing of the pedalbox
cut bushes
Ludo(a friend) had cut pedals, I just delivered a blow on the edge so that it is perpendicular to the faces.
implementation for perpendicular
a little bit hot
3 pedals welded , I also cut more rectangles of hardened stainless steel pedals (I have great poo to get in shape by following the way!)
manufacturing bushes erthalon to serve axis (6 for me and 6 for Ludo )
meanwhile , manufacturing support bracket.
and all mounted, not finish but i approch the end , and then paint.
Proby
| posted on 9/11/13 at 03:18 PM |
Excellent progress Alex, looking great.
Visit GraphicMonster
davidimurray
| posted on 9/11/13 at 05:36 PM |
Great looking build.
You may want to add a stiffening rib up the side of the clutch and accelerator pedal. I bent my clutch pedal over easily as designed but a little 3mm
rib on one side has made it nice and stiff.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
alex89
| posted on 9/11/13 at 05:39 PM |
thanks for the tips!
baz-R
| posted on 12/11/13 at 08:55 AM |
looking good and keep up the good work
check the cam chain on that twincam 8v engine if your going to use it i have repiared quit a few over the years
Not Anumber
| posted on 12/11/13 at 12:29 PM |
Excellent work.
alex89
| posted on 4/3/14 at 08:16 AM |
some news
all we need to make the rear hub carriers
preparation of template
done!
all wishbone bushes for me and ludo
fabrication, welding and painting wishbones
some other parts
GAZ shoks
just for the picture
I made the mushroom strut plug but i don't know if it's good, telle me if i must change them.
closer
mounting blank
at the back, I had noticed that I had made a mistake on the positioning of the upper wishbones, and assembly of these largely confirm my mistake ...
we could believe ...
...but no!
see it later...
quickly as I started my drive shaft via a shaft Sierrra diesel. Did not have time to make my turner a spacer, I made a following with the means at
hand, there was 0.5mm to eat
result
see you later
[Edited on 4/3/14 by alex89]
samjc
| posted on 4/3/14 at 10:16 AM |
Taking orders on the pedal setup haha looks great.
alex89
| posted on 5/6/14 at 08:24 PM |
Hey guys, here some news, and some great news, i must to show you!
2 wheels on the ground
Some modifications
And 4 wheels down at least
Futur problem...
Daft fuck! lol!
Body kit arrived, some modification are needed
Just for the picture
alex89
| posted on 5/6/14 at 08:34 PM |
Free exhaust from my brother, and a steering from 605 peugeot
Reconditionning
Close
On the roadster
And start!
http://www.youtube.com/v/2hLSAyJFqbQ
alex89
| posted on 5/6/14 at 08:39 PM |
End of steering
Steering from the 4L Renault, and 605 tie rod
alex89
| posted on 6/6/14 at 06:02 AM |
Tank fabrication
Some parts
Welding
Just fit to see the height
alex89
| posted on 6/6/14 at 06:06 AM |
Finish
NeXT step
(From Xsara Picasso)
And i installed a 3.92 ratio diff in 7,5"(but no picture)
alex89
| posted on 6/6/14 at 06:08 AM |
Brake system is also finish to day
alex89
| posted on 6/6/14 at 06:14 AM |
Cooling system finish too
And first modification for the nose cone, more wider today, and change the engine place
alex89
| posted on 6/6/14 at 06:18 AM |
Scutlle fabrication
Need to be more thick
Integration
Welding
alex89
| posted on 6/6/14 at 06:21 AM |
Fit the oil carter
All on the same level
And WTF! No hole but not pretty today
alex89
| posted on 6/6/14 at 06:24 AM |
So i made wood floor, fuel tank attached and....
She ran herself!!!!!!!
With my son in it
And a little video
https://www.youtube.com/watch?v=jizEp7Vzxqo
That's where i am today
[Edited on 6/6/14 by alex89]
YODI
| posted on 19/8/14 at 05:35 PM |
I love this, you have put great workmanship into it. I only ask, why the diesel engine?
big_wasa
| posted on 19/8/14 at 06:11 PM |
Diesel ? that's fords 2.0 dohc 8v petrol lump as fitted to late Sierra's / Granada's.
YODI
| posted on 19/8/14 at 08:59 PM |
Thats what I meant mate, honestly lol
alex89
| posted on 20/8/14 at 06:24 PM |
Same power as a diesel engine, same noise, but it's for the begining, don't worry, the futur engine will be more than 200 bhp(i hope
250!), for just a 1.6 l.
[Edited on 20/8/14 by alex89]
alex89
| posted on 20/8/14 at 08:33 PM |
I bought a hydrolic tube bender
My son must to learn...
This is my rollcage "road test". Not finish.
Welding tube for seats and aluminium floor panel
alex89
| posted on 20/8/14 at 08:43 PM |
It's raining a lot in France so i made some stuff
Cycle wing bracket and cut it for an agressive look
Put the rear muddgards
There's a lot of space between the tyre and the muddguard, i can install larger tyre later.
bad ass! 1,73m!
No courage for the second cycle wing...
