Author: Subject: Book Locost vs. Haynes Roadster
Dom C
posted on 11/2/09 at 12:59 PM Reply With Quote
Hiya,
Thinking about a self build car, and I have the Ron Champion book - 2nd edition. I was wondering what the pros and cons of a Haynes Roadster are versus the Ron Champion Locost?
Im pretty new to all this, but I can see one is IRS and one live axle, but whats the difference in handling?
Is the Haynes a bigger/heavier car than the standard locost? I wanted to make a small nippy little thing in the spirit of an MG midget rather than a balls out BEC 0-60 in 6 seconds machine...
Both books are really interesting. Just wondered what people thought... I guess there are more sierras out there than mk2 escorts, but it still seems mk 2 stuff comes up on ebay fairly regularly. Sorry if this is a really fundamental question I should know the answer to, Ive tried to find an existing post!
Mr Whippy
posted on 11/2/09 at 01:23 PM Reply With Quote
Really the IRS has better grip on bad road surfaces and will be easier to get the donor parts for. The Haynes roadster is a much better written and more accurate (but not 100%) book too. Both weight about the same though depending on the engine and gearbox fitted. There’s also a single seater book coming out next year btw but that will most likely be a BEC..
[Edited on 11/2/09 by Mr Whippy]
cd.thomson
posted on 11/2/09 at 01:36 PM Reply With Quote
youll end up close to 6 seconds with just a pinto in it anyway
Craig
Mr Whippy
posted on 11/2/09 at 01:39 PM Reply With Quote
considering my 1600 cortina could do it in 8 seconds, thats not asking much really
paul the 6th
posted on 11/2/09 at 02:24 PM Reply With Quote
http://www.haynes.co.uk/forums/index.php
dedicated haynes roadster forum which is growing all the time also features ammendments and lots of helpful people who've built the roadster already..
chris gibbs is on the haynes roadster forums (and on here as well ) very helpful fella and knows his stuff
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
smart51
posted on 11/2/09 at 02:25 PM Reply With Quote
I'd choose the haynes roadster over the original locost any day except:
1) you have a donor escort that you want to convert
2) you want to go locost racing and have to build the car by the book.
Sierras are much more plentiful donors. I'd also look at the single seater because it looks nicer.
cd.thomson
posted on 11/2/09 at 02:58 PM Reply With Quote
how do you know?
Craig
3GEComponents
posted on 11/2/09 at 04:02 PM Reply With Quote
how do you know?
See here, http://www.locostbuilders.co.uk/viewthread.php?tid=104646 thanks to Amazon, it's all out in the open, although a few of us already knew
Regards
John
CaptainJosh
posted on 11/2/09 at 05:58 PM Reply With Quote
The book car IS lighter. The sierra running gear is allot heavier overall and the book car is smaller than the roadster.
Also you only have to make 4 wishbones as opposed to the roadsters 8.
And I'm not even building a book car
robertst
posted on 11/2/09 at 07:44 PM Reply With Quote
AHA!!! you see thats not quite accurate because you still have to manufacture those BLOODY trailing arms which are a right nightmare to build.
i use both books at all times to get a clear picture, but if i were starting again, i'd Definitely follow the new one.
also, i would consider getting all the running gear, etc from the sierra but source a nicer, more refined engine than the pinto such as a zetec, which can be easily joined with a type-9 gearbox u find in a sierra.
cd.thomson
posted on 12/2/09 at 10:58 AM Reply With Quote
Regards
John
Dont worry, im following the thread closely, that is a computer generated though which is what I was joking about
Craig
Dom C
posted on 12/2/09 at 12:46 PM Reply With Quote
Is there a race series for the Haynes too? Im not really planning on making a car to race, but itd be nice to have the chance if I fancied.
Also, I know its chickening out a bit, but can you buy ready made wishbones for the Haynes, professionally welded?
Cheers for the feedback/info
Dom
3GEComponents
posted on 12/2/09 at 10:02 PM Reply With Quote
Dom
Try these guys
http://www.3gecomponents.com/templates1/index.php?site=63
Regards
John
[Edited on 12/2/09 by 3GEComponents]
