squbti
| posted on 12/4/09 at 08:55 AM |
Need help with U7, 8 & TR5 !
Hi, I´m building the Haynes roadster in Sweden & as you know the stearing here is on the left, so I was woundering what to do about U7,U8 &
TR5 ! Can I just switch them arownd (mirror them)?
Also , I can see TR5 on all the drawings but not in any photos in the book or any of the builds I´ve seen on the net , so should I have a TR5 or not ?
Thanks ,
Samy
handyandy
| posted on 12/4/09 at 09:10 AM |
Hi Samy,
not sure what you need to do regarding making the chassis into left hand drive but the TR5 i believe some people don,t weld into place until the
engine has been trial fitted as it may or may not get in the way when placing the engine into the chassis, sounds like i,m at the same stage as
yourself, i,ve tacked TR5 into position at the moment to ensure the chassis is as per the drawings but may remove it to place the engine in then fully
weld in place.
hope that suggestion helps,
all the best with your build.
andy
handyandy
| posted on 12/4/09 at 09:17 AM |
Samy,
i,ve just looked on the Haynes forum( sorry don,t know how to do a linky), there is a section detailing all that needs to be done to change the
chassis into left hand drive, descriptions & detailed drawings, this might answer your questions.
the section is in the "Announcements" page about 5th thread down the list.
cheers
andy
AdrianH
| posted on 12/4/09 at 09:21 AM |
The link is
http://www.haynes.co.uk/forums/showthread.php?t=61
Adrian
Why do I have to make the tools to finish the job? More time then money.
handyandy
| posted on 12/4/09 at 09:22 AM |
Thanks Adrian,
me & computers
cheers
andy
squbti
| posted on 12/4/09 at 09:23 AM |
Hi Andy , thanks for the reply & all your help . I think i´ll do just like you say with TR5 just tack it at first & fully weld it when i know
for sure . I´m going to take a look at the Haynes forum now to see about that thread .
Thanks agin for all the help
Samy
squbti
Samy
squbti
| posted on 12/4/09 at 09:42 AM |
Thanks for the link Adrian, it´s all there .
great help
Samy
handyandy
| posted on 12/4/09 at 09:47 AM |
clever bloke that Mr Gibbs,
what engine are you using? donor?
i,ve just finished putting the transmission tunnel into my chassis, doing the steering column supports today.
cheers
andy
squbti
| posted on 12/4/09 at 10:06 AM |
I´m using a Fors sierra 2.0 L from 85 , it has the SOHC . I´m just starting now with the TRs but should be done with that this week if I get some time
away from the wife & kids
Samy
handyandy
| posted on 12/4/09 at 10:19 AM |
good luck with the build, i,m lucky as i,m building my car away from my home address so when i go to work on my chassis i don,t get any
interuptions from the family
i suggest you join the Haynes forum as that site is dedicated to the Haynes roadster chassis, this site is a wealth of info for lots of kits & the
two sites go side by side to give every bit of help & information you could ever need, & everyone seems to have the same goal = help to any
builder of a kit to get another on the road.
best of of luck.
andy
Canada EH!
| posted on 12/4/09 at 05:17 PM |
I got a LHD Escort quick rack from Rally design, warked well with the Locost chassis
