simon chapman
| posted on 17/4/09 at 09:27 PM |
Noise levels
I need to know the noise level limit for the SVA/IVA some say 94 Db and some say 97 got a meter just need to know level
| posted on 17/4/09 at 09:36 PM |
Is the noise meter calibrated? Otherwise I wouldn't bother. Most are +/- 3-4dB which is (in terms of noise level) double to three times as much
(or there's about, my log maths is failing me tonight after a little bit too much vin rouge).
IE you can quite spectacularly fail the SVA/IVA noise test despite a cheapy uncalibrated unit saying you're A1....
iank
| posted on 17/4/09 at 09:44 PM |
SVA 101dBA @ 500mm and 45 degrees from the exhaust exit.
IVA 99dBA @ 500mm and 45 degrees from the exhaust exit.
IVA from Draft 3.2, SVA from the manual
Note it's dBA not dB they measure
http://en.wikipedia.org/wiki/A-weighted for the difference if you don't know
[Edited on 17/4/09 by iank]
Anonymous
smart51
| posted on 18/4/09 at 06:58 AM |
99dB for IVA.
BTW, 3dB represents twice the noise POWER but only a small increase in perceived volume. If you turn the radio up or down "a bit" most
people adjust it by about 3dB. 10dB is twice or half the perceived volume.
