Author: Subject: collapsable steering column
squbti
posted on 23/4/09 at 07:10 PM Reply With Quote
Hi all, I´m building my Haynes roadster in Sweden & according to the law here the steering column has to be collapsable so you dont get pinned to the seat in case of an accident, so I was woundering if anyone had used something like that & what could I use on the Haynes roadster that would be compatable with the Ford Sierra steering wheel & column.
Thanks ,
Samy
Miks15
posted on 23/4/09 at 07:13 PM Reply With Quote
I believe its the same law here, and i think im right in saying that the sierra column is collapsable
Someone will be along im sure to confirm/correct this
londonsean69
posted on 23/4/09 at 07:14 PM Reply With Quote
As far as I am aware, the steering column from th Sierra IS collapsible.
But I could be wrong.
Sean
Edit - damn, beaten to it by mere seconds
[Edited on 23/4/09 by londonsean69]
handyandy
posted on 23/4/09 at 07:27 PM Reply With Quote
i,m building the roadster too & will be using the donor steering column, so as far as i,m aware the sierra column is ok to use.
tho it does need to be extended.
andy
mr henderson
posted on 23/4/09 at 08:34 PM Reply With Quote
According to the Haynes Sierra manual, all versions of the Sierra have collapsible column, although there are various types of outer colum,
John
