Author: Subject: Windscreen fitting
SandyC
posted on 12/2/10 at 12:54 PM Reply With Quote
Windscreen fitting
Hello all,
I'm looking for some help/ advice.
I'm about to replace my fly screen with a windscreen on my Tiger Avon, the flyscreen is fitted with the std Tiger uprights bolted to the GRP scuttle, do i need to bolt them to something more secure, or will the GRP be strong enough?
Any advice on fitting the windscreen in general would be appreciated.
Sandy
whitestu
posted on 12/2/10 at 01:01 PM Reply With Quote
Just use some big washers on the inside of the scuttle to spread the load.
Make sure you get the angle of the screen right before drilling any holes.
Are you fitting a hood? If so the screen will need to be in the correct position in relation to the hood.
Get some sidescreens as they make a massive difference once you have a screen on.
Stu
SandyC
posted on 12/2/10 at 01:24 PM Reply With Quote
Hi Stu,
Thanks for that, i'm hoping to use the holes already drilled in the scuttle for the fly screen, just wasn't sure if the GRP was strong enough for a full windscreen.
I wont be fitting a hood, not even planning on fitting wipers at the moment, i'll probably change back and forth between windscreen and fly screen
cheers Sandy
whitestu
posted on 12/2/10 at 01:34 PM Reply With Quote
My scuttle is fibre glass and has been fine with the screen on so assuming yours is a similar thickness should be OK.
Canada EH!
posted on 12/2/10 at 03:07 PM Reply With Quote
Put some fender washers on the inside to spread the load on the GRP
graememk
posted on 12/2/10 at 04:21 PM Reply With Quote
i cut some ali plate out and PU'd it to the back of the scuttle then used big washers
