Dunbikin
posted on 4/11/12 at 02:35 PM |
Griffin (style) plenum
Hi all,
I am just in the process of fitting a 2L Zetec silvertop into my Locost. I am having a problem fitting the inlet plenum as the 2 small pipes coming
from the bottom of the chamber are hitting a chassis rail. Can anyone tell me what these two pipes are for, can I just cut them off and block the
holes or move them so they don't foul the chassis rail. Thanks Nigel
[Edited on 4/11/12 by Dunbikin]
[img]pg]94546[/pg][/img]
Ron said it would cost 250 quid. My wife thinks it did.
40inches
posted on 4/11/12 at 02:47 PM |
![](/galpreviews/Griffin plenum.jpg) ![Inlet plenum](/gallery/Griffin plenum.jpg) Inlet plenum
Dunbikin
posted on 4/11/12 at 02:56 PM |
I've been trying for the last 20 mins to upload that photo. Thanks. The 2 pipes pointing up are the ones I mean, on my plenum they point down.
big_wasa
posted on 4/11/12 at 03:01 PM |
They use one for the fuel rail regulator and one if needed for a brake servo.
Either cut them short and tap them to m6 and fit a bolt with some sealant or cut them short and plug weld it.
Dunbikin
posted on 4/11/12 at 03:05 PM |
Thanks Wasa, I will get cutting and plugging.
big_wasa
posted on 4/11/12 at 03:19 PM |
I did have some pic's but cant find them. The plenum above, the ports are pointing down. The inlet is on the other end for fwd setup.
I modify them a little as I hate the nasty bleed screw idea.
[Edited on 4/11/12 by big_wasa]
