hopsky1
posted on 27/6/13 at 12:34 PM |
919 blade fuel pressure
Hi.my fuel pumps packed up on my blade mnr.ive got a trackday booked sat.i can get a facet fuel pump localy.what fuel pressure do i need?.they do one
2.5-3 psi is this ok?
MK9R
posted on 27/6/13 at 12:40 PM |
Yup that will be fine
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Benzo
posted on 27/6/13 at 06:23 PM |
buy a self regulating bike pump for the 919 or a ninja. Much better job, no need for a reg.
MK9R
posted on 27/6/13 at 06:25 PM |
Facet pumps are usually self regulating
Cheers Austen
RGB car number 9
www.trackace.co.uk
Benzo
posted on 27/6/13 at 06:27 PM |
Around 3 times the price tho?
mark chandler
posted on 27/6/13 at 07:02 PM |
I ran my blade on carbs with a low pressure facet pump without any issues, it's still supplies my swirl pot today and cost less than £30
One of these
FACET ELECTRIC FUEL PUMP ULTRA LOW 4PSI NO REGULATOR REQUIRED 4 CLASSIC CARS EO | eBay
hopsky1
posted on 27/6/13 at 08:49 PM |
One of these
thats the one the car has fitted at the moment it now rattles all the time like its out of fuel but the car runs fine.ive orderd a new one but might
not be here for sat trackday.i fitted a facet solid state low pressure pump today but fuel was pissing out the carbs and flooded the engine so ive
refitted the old one.
MK9R
posted on 27/6/13 at 08:55 PM |
Take the black cap off at the end and clean the the points up with emery cloth, it could just be the points.
If fuel was pissing out, are out sure a float hasn't stuck open?? Has it stood for a while with no fuel in the carbs, if so the o rings dry out
and it leaks. Once they have been left to soak in fuel they expand again and its All fine
Cheers Austen
RGB car number 9
www.trackace.co.uk
hopsky1
posted on 27/6/13 at 08:59 PM |
its used regualry.runs fine on the old pump just the pump rattles interminatly as if its running out of fuel
MK9R
posted on 27/6/13 at 09:01 PM |
That sounds like points!!! Clean them up and I bet its fine!!! But also check filter, only blade pump I ever knackered was due to filtering being
blocked and pump ran dry and burnt it out
Cheers Austen
RGB car number 9
www.trackace.co.uk
hopsky1
posted on 27/6/13 at 09:04 PM |
the old pump isnt a blade pump its this one
ive put a new pre filter on its still the same
mark chandler
posted on 27/6/13 at 10:41 PM |
If you are drawing in any air it will do this, try clamping the pipe, if that stops it rattling them you have your culprit.
Thurbs
posted on 28/6/13 at 09:57 AM |
Buy a bike pump if I was you, Honda's R & D budget quite big so I'd use something designed for the job.
