rick1962uk
| posted on 15/9/13 at 05:48 PM |
At last my build starts
well after 4 years i have now some time i can start my build its going to be a haynes based zzr1100 track only car i hope to do a first shake down in
may-june but subject to race commitments colected most of the running gear and steel and just brought a new invertor mig pluss i have a small tig
i realy want it to be sub 450kg but will be a challenge
[Edited on 16/9/13 by rick1962uk]
ste
| posted on 15/9/13 at 10:49 PM |
Nice welder. Where did you bring it from?
rick1962uk
| posted on 16/9/13 at 08:51 AM |
i got it from R-techwelding.co.uk cost just over £440 but i will use it a lot and its an inverter so should run a lot better i was just fed up will
all the diy welders i brought over the years
A few more parts ready to paint
ZZR1100 engine to go in
nice little mill for cutting and facing the box steel
[Edited on 17/9/13 by rick1962uk]
rick1962uk
| posted on 14/10/13 at 06:18 PM |
Build Table built now to start cutting and welding
rick1962uk
| posted on 15/10/13 at 06:53 PM |
cutting starts this makes it easy
Not bad for half a days work
Uphill Racer
| posted on 16/10/13 at 11:41 PM |
Looking good and a nice strong engine choice. I ran that engine in my single seater without any oiling problems due to the pickup design. Forgive me
if I’m teaching you to suck eggs but are you aware that fitting the GPZ 900 sump and pickup will allow you to lower the engine?
rick1962uk
| posted on 17/10/13 at 06:27 PM |
many thanks and yes i will use the gpz sump and pick up pluss its only for track days so new oil every time the plan is to cut my teeth on this one
then go for a zzr1400 one mid engine
rick1962uk
| posted on 27/10/13 at 04:56 PM |
Had a good morning after sorting out that sodding front frame it went together quick but ran out of steel so more ordered
rick1962uk
| posted on 31/10/13 at 06:59 PM |
had a good day on the chassis
decided to clamp the chassis down to the board and make sure its 100% true with no twists as im sure when the diagonal bars go in it will be almost
impossible to get back square
rick1962uk
| posted on 31/10/13 at 07:50 PM |
veiw from the rear
joneh
| posted on 3/11/13 at 07:15 PM |
You're about at the same stage as me
I noticed your u7 is in the wrong place, making the transmission tunnel wider. Don't know if this is by choice but would have thought
you'd have made it smaller, if anything, with a bike engine?
rick1962uk
| posted on 5/11/13 at 07:12 PM |
Had another good morning on the car got most of the chassis done its starting to look like a 7 now
http://i1298.photobucket.com/albums/ag52/rick1962uk/Haynes%20kitcar%20Build/Picture014_zps56e6c8a1.jpg
i clamped every corner with these angle bars with 10mm studding to try to keep the warping down as low as i can im going to leave the wishbone
brackets untill last that way i can make sure they are all level even if the chassis is a bit out
Trouble is i have to get on with building some bikes so the kit will slow down for a few weeks
rick1962uk
| posted on 5/11/13 at 07:15 PM |
many thanks i did notice after i have moved it now not much but i have kept it wide just in case i want a car engine in there
rick1962uk
| posted on 9/11/13 at 09:41 PM |
Managed to get all the welding on the chassis done today just the rear end to do then onto the arms but might leave them untill the Christmas holidays
as the race bikes are behind schedule so need to catch up then back on the kitcar
rick1962uk
| posted on 19/11/13 at 05:27 PM |
Had a bit of time today to kill so got the diff frame made starting to look like june target will be achieved
Simon
| posted on 19/11/13 at 06:28 PM |
Hahahahaha
I got to a rolling chassis from steel tube in two weeks, and it took another three years to get on the road
I do wish you luck though, and I'm starting to think I may scratch build again seeing yours
Simon
rick1962uk
| posted on 10/12/13 at 05:39 PM |
Rear end Done wishbones next
rick1962uk
| posted on 15/4/14 at 05:43 PM |
After a few months off due to work managed to get back on with the haynes
Front Lower Wishbone Arm Getting Machined
all jigged ready to weld
rick1962uk
| posted on 18/4/14 at 04:17 PM |
All welded and reamed the bushes out now onto the top ones
big_wasa
| posted on 18/4/14 at 04:51 PM |
Keep it up
rick1962uk
| posted on 27/4/14 at 02:17 PM |
Another good morning managed to ream out the wishbones greased and fitted bushes and popped a coat of paint on getting on so well if i can have a
good day tuesday i might have enougth time to go to the kitcar show
scutter
| posted on 27/4/14 at 02:52 PM |
Looking good there fella, keep it up.
I'm over at Brize Norton if you fancy chewing the fat?
Regards Dan.
serieslandy
| posted on 27/4/14 at 05:08 PM |
I would advise putting another spar in for the fuel tank to sit on
rick1962uk
| posted on 27/4/14 at 05:39 PM |
it will only have a 2 gallon one so should be ok but will test first many thanks
rick1962uk
| posted on 27/4/14 at 09:13 PM |
Regards Dan.
hi dan would love to a bit tied up with racing at the moment but should have a bit more time on my hands in a month or so
