alice
| posted on 8/12/13 at 04:39 PM |
Can anyone identify this car?
Does anyone know what the make of this kit car might be or who built it as I bought it without any details at all. I've checked a few sites but
not seen one similar. It has a Vauxhall red top engine but is missing an ECU. Does anyone have any suggestions?
Smokey mow
| posted on 8/12/13 at 04:48 PM |
The same question was asked over on the WSCC a couple of weeks ago. It's an SPD 7
http://forum.wscc.co.uk/forum/index.php/topic/105352-name-this-car-time/?p=1097642
iank
| posted on 8/12/13 at 05:21 PM |
Now called a cradley motor works snake.
http://www.sportsandleisurecars.co.uk/
[Edited on 8/12/13 by iank]
Anonymous
bob
| posted on 8/12/13 at 05:40 PM |
Many name changes, if you search SPD or snake they make interesting reading.
bob
| posted on 8/12/13 at 05:58 PM |
After a little thought re this car, i am sure an issue came up regarding welding issues as well as design issues with front wishbones, also if you
study the first picture are the front hubs handed left for right the wrong way.
James
| posted on 8/12/13 at 08:35 PM |
Check it over very thoroughly, ideally with the help of someone experienced.
The issue Bob has highlighted is one to note but also the camber adjusters (if they're the Ali type they appear to be) have a history of failing
and should be changed for steel ones.
Best of luck with it, James
- Muhammad Ali
alice
| posted on 8/12/13 at 09:15 PM |
Unknown car
Thanks to every one who has replied to my thread. After checking on the internet I think you are right in saying its a Snake. I will also take note of
other comments re the camber adjusters. As I am very new to this (coming from a motorcycle background) any tips and suggestions would be most welcome.
What a great bunch you are! TAZ
rick1962uk
| posted on 9/12/13 at 01:10 PM |
Hi taz the injection looks like a bike set if i was you i would go back to a vauxhall set up get it running then play with it a std set up will be as
quick as you would want for the first year
alice
| posted on 9/12/13 at 04:08 PM |
kit car
Thanks rick.
Not Anumber
| posted on 9/12/13 at 07:42 PM |
Interesting beat, looks like a 7 from the front and a Cobra from the back.
jossey
| posted on 9/12/13 at 08:29 PM |
As above wtf is with the top wishbone :-)
David Johnson
rick1962uk
| posted on 9/12/13 at 10:13 PM |
if you take off as much body work as possible i have 2 weeks off over xmass so could pop up and have a good check over with you
