Rosco86
| posted on 16/10/14 at 05:45 PM |
13" wheel fitment
Hi there, I'm new to the site, going to start my Haynes chassis this weekend, ive had a search on here but cant find an answer, i want to use
13" alloys but found that they catch, is there a way round this, this chap here http://m1kemph.wordpress.com/2011/04/ seems to have fitted them
but not much more info than that, any help would be great
davidimurray
| posted on 16/10/14 at 06:11 PM |
Unlikely without new rear uprights and modified rear suspension. If you have a look in my galleries you should see how tight they are. You need
15" alloys - even the original 14" steels won't fit.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
mark chandler
| posted on 16/10/14 at 06:16 PM |
30 years ago most cars came with 13" wheels, so you need to define catch.
If you fit brakes designed for a 15" wheel then yes they will catch, also not all wheels provide the same amount of space.
I tried some old revolution 4 spokes on my car, okay on the front discs but fouled the rear sierra 14" wheel rear callipers so moved to original
mini lights.
These also fouled in the inside edge with the rear callipers but a 1/2" spacer would have sorted this out as the wheels had a lip on the back of
the centrer plate, next tried mini light copies, minator and loads of room
I could have used inset discs and relocated the rear caliper and used mini lights.
So decide what combo you want then get measuring, remember big callipers = big discs = big wheels and tyres = more leverage for the same tyre profile
so little discs on little wheels are just as good, just much cheaper and work far better.
Regards Mark
Rosco86
| posted on 16/10/14 at 06:37 PM |
yeah thats what i seem to have read about having to use 15"s, ive not built anything yet so didn't really mean catch, but will be buying
new wheels so can buy the most spacious alloys, im aiming on using std sierra rear discs and probably some wilwoods up front, i would prefer to run
13"s and dont mind a bit of alteration but wondered if someone had already done it
thanks for your replys
