snakebelly
posted on 26/3/15 at 01:31 PM |
NODIZ Pro Complete Setup (Price Drop)
Was fitted to my Ribble kit but have now decided that a period looking distributor based system is more in keeping. Its only been fitted to run the
engine up so less than an hours run time. Comes with a brand new Ford coil pack and 2 VR sensors. I will also throw in the coil pack mount but will
have to cut it off its mounting so will need cleaning up. Also will throw in some hi spec silicon plug leads in blue that will fit the coil pack. Also
included is a full loom less the TPS plug. The Coil plug will have to be cut off to get it back through the bulkhead but will leave plenty of meat for
you to join it back up. The unit is on its way back from Matt at the moment as I sent it off to have its firmware upgraded so it will be bang up to
date and tested by the factory.
Cost from Motorsports Electronics for the Nodiz, Coil Pack and 1 VR Sensor is ££341.49.
First to shout out gets it for £250 gets it.
[Edited on 27/3/15 by snakebelly]
snakebelly
posted on 26/3/15 at 08:12 PM |
The coil pack mount was only bolted on so is perfect and unmolested.
snakebelly
posted on 27/3/15 at 12:53 PM |
Last chance before it goes on EBay...£225 posted
