steve-hv8
| posted on 1/5/15 at 04:35 PM |
new build
well now that ive actually got my donor car the hard work now begins
donor car i got is a mk1 mx5 1.8 jap import
need to start stripping it while i try and get a chassis sorted
any bits of the car i dont need will be for sale to save throwing them away,well if anyone wants them
so im on the lookout for a chassis,anyone know where theres one available maybe a build thats fell through
or a flat pack kit that never got started
icthing to get going with this now
steve
ian locostzx9rc2
| posted on 1/5/15 at 05:00 PM |
Stoneliegh kitcar show this weekend for inspiration.
steve-hv8
| posted on 1/5/15 at 05:05 PM |
yes me and my boys are going for that very reason
rash12
| posted on 1/5/15 at 08:39 PM |
i know its not a haynes roadster but were going Monday in our sr2 mx5 your more than welcome to have a good nosey round if you need to measure
anything etc etc
steve-hv8
| posted on 10/5/15 at 04:26 PM |
so i went and picked a chassis up today
its a book spec sierra chassis so im going to have to rework some of it to suit my mazda diff
or i just try and source a donor sierra and sell the mx5
prawnabie
| posted on 10/5/15 at 06:30 PM |
Steve, if you google westfields MX5 chassis, they just used the standard sierra diff mounts with a bracket attached for the nose mount, and a pair of
brackets bolted between the upper wishbone mounts and the upper shocker mount to bolt the arms to, may save you having to chop up your rear end.
garyt
| posted on 10/5/15 at 06:39 PM |
Just looking back through the gillham / saturn drawingstop of the diff cage bottom and back as you have and the rear portion of the transmission
tunnel not to much work
Can send you a copy if needed
Good luck Gary
remember we are not mad just creatively insane !!!!!
garyt
| posted on 10/5/15 at 06:50 PM |
Also have a copy of rear upper wishbone dimensions if you require, no connection or interest but I had craig at plazcut do the plates for the Saturn
wishbones front lower and rear upper, saved a lot of work
Gary
steve-hv8
| posted on 10/5/15 at 07:28 PM |
ive got a 45 page guide from saturn,is that the same one your on about?
Gary
steve-hv8
| posted on 10/5/15 at 07:38 PM |
theres still a few bits to weld onto the chassis
steering rack mount
engine mount plates
cp9
cp14
cp18
cp16
cp17
and a few other bits
also will tr5 be in the way of the mx5 engine
garyt
| posted on 10/5/15 at 09:13 PM |
Hi yes its the 45 page Saturn guide you will get the top rear wishbone dimensions in my photo archive, , when using the mx5 uprights pay attention to
the bolt sizes , they are different to the drawings , would need to check before quoting sizes.
Re the chassis TR5 I did not use allows more clearance round the engine, cp9 if using a fiberglass rear tub you will not have a toprail and so no cp9
attachment point means the rear rollbar stays have to go elsewhere you can see how I did mine in the latest photos , others have taken them right down
to the rear bottom corners, cp14 handbrake cable plate again its used but holes to suit mx5 cables ,cp16 if using the mx5 column then follow Saturn
guide and use the bearing illustrated not as per book also worth using thicker plate for this and the pedal/ mc backplate (again I got mine from
plazcut ), cp17 I did this for the passanger footwell aswell, cp18 lower seatbelt mounts I bought from demon tweeks fia weld in harness mounts.
I spent quite a while going through other mx5 builds on all the forums picking out ideas and how to's, feel free to go through my archive and if
you need any other photos or info I'll do my best to help.
Regards Gary
steve-hv8
| posted on 12/5/15 at 07:10 PM |
been looking at the chassis today and seen as its a sierra based one
im going to cut the rear tubes to fit the revised tubes for the mazda diff
now what would be the best way to cut it with out doing to much harm to the tubes that dont need revising
hacksaw would take ages so im thinking maybe a reciprocating saw?
whats your thoughts guys
garyt
| posted on 12/5/15 at 07:56 PM |
cut the tube as close to the weld, cutting disc in angle grinder then grind back to dress the good tube if possible do one tube at a time thus
minimising any risk of distortion, or if you have a build table clamp it down so its flat, trying to think , but if you cut out out cp10 and sb4 then
weld in new sb4's to suit the mx5 diff, then do the rear trans mission tunnel tubes 1 at a time,
as the bottom framing on the diff cage stays as is, you should be able to cut out the top frame, make up the new frame off the chassis and then weld
in .
I think the hardest part will be the top shock mount are they there? if so not sure the best way to remove for new ones to go in the correct
position
remember the ones coming out are sacrificial so it doesn't matter if they come out in small sections rather than in 1 piece, it may make access
easier as you go
Gary
steve-hv8
| posted on 12/5/15 at 08:05 PM |
yes both the top shock mounts are there
so thats more work
garyt
| posted on 12/5/15 at 08:25 PM |
hi leave the shock mounts where they are ie 20mm to far back from mx5 position then when you make your rear upper wishbone the top plate that the
lower shock mount is welded to extend rearwards by enough to move the mount rearwards by 20mm this should then line up the shock mounts and be far
easier than trying to change the upper plate will do a drawing if need be but hopefully you follow, this would work because it is 5mm plate and is
welded on top of the tubes so extending it a small amount should be fine.
Gary
garyt
| posted on 12/5/15 at 09:00 PM |
diff mount plates on ebay item number 281067952783
