Mudchute
| posted on 7/5/15 at 06:35 PM |
Another mx5 build.
Hi everyone,
So, I've started my build. I've been lurking here for a while but the day came and I've started.
I'm going for a mainly book chassis with alterations to use mx5 donor parts. I intend to use Saturn design wishbones other the rear upper which
is a bridge I'll have to cross when I get there. I'll also use the talon diff parts to fit that.
I've bought the bare steel and I've been using the mill I currently have use of to prep the ends.
I've also elected to tig it all together as I've always wanted a tig welder and this was a perfect excuse!
I would have done more today but only half the steel I ordered arrive. Does 32m of 25mm box and about 12m of 20mm box steel sound about right?
I'm hoping to have the chassis ready to go in the next couple of weeks. I've been acquiring mx5 bits as well and have a gearbox, diff and
prop. I pick up an engine and all 4 uprights tomorrow.
Wish me luck!
| posted on 7/5/15 at 06:39 PM |
Champion, will be watching with great interest. Some nice toys in the garage there!
Keep the updates and pics coming.
big_wasa
| posted on 7/5/15 at 06:58 PM |
I love a scratch build
I must get my finger out.
davidimurray
| posted on 7/5/15 at 08:03 PM |
Good Luck
I tig welded all my chassis as well, took some time but was very satisfying.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
garyt
| posted on 7/5/15 at 09:06 PM |
nice start, keep the pics coming and good luck
Gary
remember we are not mad just creatively insane !!!!!
Rosco86
| posted on 7/5/15 at 10:00 PM |
Nice to see another scratch build, not manny people seem to bother these days, nice garage to!
Mudchute
| posted on 9/5/15 at 07:18 PM |
Thanks for the comments guys.
I completed the front frame yesterday. I don't like the front frame. Its a hateful piece of metal!
I've got a couple more days off this week so hopefully more will rise up from the table. I found some spare cash to buy all the necc metal so
its all down to me now.
| posted on 9/5/15 at 07:20 PM |
Can I ask what tig welder you have and how your getting along with it?
I'm thinking of buying one for my chassis....
And, what's so hateful of the front frame?
big_wasa
| posted on 9/5/15 at 08:39 PM |
quote: Originally posted by coozerAnd, what's so hateful of the front frame?
The compound mitres at a guess ?
Mudchute
| posted on 9/5/15 at 09:03 PM |
It's a TigMig TM200HF eBay special. It's an inverter type tig/stick unit.
Is it any good? Seems so however I'm no welder and this is the only tig unit I've used. Seems like it's good for the job.
Yes the compound mitres. Once I clicked the mill allowed me to get them spot on. The rest I made a mess of.
Mudchute
| posted on 12/5/15 at 09:54 PM |
Some more progress.
That'll be it until next week. I'm hoping to have the chassis complete the week after next.
Rosco86
| posted on 13/5/15 at 07:59 AM |
looking good! i think it starts out easy and just gets harder lol
Slimy38
| posted on 13/5/15 at 08:17 AM |
It's probably a bit late now, but did you read the revisions for the Haynes chassis, in particular around that front frame? If you've not
seen them, I suggest you head over to;
http://www.haynes.co.uk/forums/showthread.php?t=2430
There's also a slight twist required that Talon told me about. The way it's built up in the book doesn't present a flat face to the
suspension bracket, it's very slightly off.
Mudchute
| posted on 13/5/15 at 08:20 AM |
Hi guys,
Yes I found those a few days ago. In the end I made the frame from six pieces and machined the ends. It went together perfectly after. It's then
I realised the angle bracket faces. I guess people are putting small shims between the brackets and bars to mount them flat?
Slimy38
| posted on 13/5/15 at 09:56 AM |
quote: Originally posted by Mudchute
Hi guys,
To be honest, I wouldn't be surprised if people set the brackets up in the jig as the book describes and then just weld on that basis. The gap
is quite tiny, maybe less than a millimetre? See what you get when you build the jig and put the brackets in place.
Personally I set them up in the jig, then as an added measure I clamped the bracket to the frame before welding.
Rosco86
| posted on 13/5/15 at 11:52 AM |
what i ended up doing was getting all of the chassis tacked together, then when it came to fitting the suspension brackets using the jig, one side had
a gap and the other didn't so i un tacked the top frame and tweaked it out a little to close the gap, if i remember right it was only 1-2mm but
made the fit on the bracket loads better
Rosco
Mudchute
| posted on 15/5/15 at 09:47 PM |
Some more progress, all the diagonals are in and I've released the chassis from the build table to assemble the rear end. I am however in two
minds again as to how to arrange the diff/suspension.
I was going to assemble the rear as per the book and mount the diff with the TMXR diff cover but thats money I can't afford to spend.
This then leaves the Saturn version with its short upper arms which bothers me. Has anyone here driven both versions?
The front suspension mounting tubes have confuszzled me. I can't quite get my head around the drawing in the book which shows where the tube
joins the upper frame rails.
The above is mine (its the same both sides), does it look correct? If so I'll neaten it up and join them to the frame rails. I got a bit carried
away tacking the bracing tubes together there and completed those two joins. Tig welding is seriously addictive!!
I'm hoping the main chassis will be done next week and I'll then start mounting the engine. I would crack on with the wishbones but
that'll have to wait until payday. I can make the assembly templates before then.
I do have some parts to refurbish which'll keep me busy and I pick up some OE 15" MX5 wheels tomorrow as well. If everything goes
swimmingly it could be sat on its own wheels next month.
This build bug has really bitten into me, I can't leave it alone.
[Edited on 15/5/15 by Mudchute]
Mudchute
| posted on 15/5/15 at 09:53 PM |
Ah, some other questions for those in the know.
The diff will be mounted solidly to the chassis whether I go TMXR or Saturn. How will this be affected by the engine and box on their movable mounts?
I was thinking of mounting them both on polybushes...
Also, one of the lower side to side tubes and bowed slightly meaning the its sticks out under the car by a couple of mm (its the one you chop the
centre part out of to accomodate the trans).
I think my build table isn't as flat as I thought. Everyhing else is square and dimensionally correct but this got me thinking about an
acceptable tolerance. So far I've been lucky enough to mill the correct angles and overall tube lengths accurately (to within 0.5mm or 0.5 of a
degree) but I accept its likely to go out in places once welded or pefore so, is there an accepted tolerance people work to?
NigeEss
| posted on 15/5/15 at 11:21 PM |
I hate to be the bearer of bad news but looking at your chassis pics you have made a huge fundamental error....
The tea mug is on the chassis...a metal surface.........the tea goes cold far too quickly
Mudchute
| posted on 16/5/15 at 01:16 AM |
All joking aside, I have been suffering from cold tea syndrome lately. I put it down to my frantic efforts to get as much done as quickly as
possible and forgetting about it however, your theory has weight...
Slimy38
| posted on 16/5/15 at 09:38 AM |
The vertical one on mine has the outside corner going directly into the top rail, it's not sticking out at all. From memory the book is wrong on
that one, it quotes the wrong corner as needing to be in line with the edge of the top rail. I believe the amendments quote the right approach.
Solidly mounting the diff won't make any difference to the car. Sierra diffs have been mounted solidly for years and never suffered any ill
effects. Just make sure you're consistent, either mount the arms and the nose all via bushes or all solidly. Don't mix and match.
I think front to back mine has about a 2mm 'curve', with the middle slightly higher than the ends. There's no twist, or at least
nothing I can measure.
Mudchute
| posted on 16/5/15 at 09:26 PM |
Thanks Slimy, I'll revisit the front tubes and see why its different and I'll ensure the diff is either completely rigid or bush mounted
all round.
I think the tube thats slightly out will partially correct itself once I chop out the bit that isn't needed. We'll see.
Does this steering wheel look sva friendly?
Ebay MX5 steering wheel
Mudchute
| posted on 18/5/15 at 08:56 AM |
Is 1.5mm walled erw round tube ok for the wishbones?
| posted on 18/5/15 at 09:24 AM |
I'm going to use landrover trailing arm tube.
I also spotted a bin in the garage at work where they service and repair the trucks. They throw out steering drag links complete when the ball joints
go and they are seriously strong. This so all due to me going through 3 sets of front bones on my last one (bending)
Slimy38
| posted on 18/5/15 at 09:32 AM |
I used;
19mm x 1.5mm x 3000mm ERW
25mm x 1.5mm x 5000mm ERW
33.7mm x 2.6mm x 1500mm (bush tubes)
That left me with about six inches of spare material so was extremely close.
