Author: Subject: Pedal box for use with bike engine
locost7-online.com
posted on 28/7/15 at 07:10 PM Reply With Quote
I'm going to fabricate the Haynes pedal box , is there any mods when using a bike engine?
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
Badger_McLetcher
posted on 28/7/15 at 08:46 PM Reply With Quote
It's a cable operated clutch isn't it? If so you should be fine. Might be worth looking at the alternative design one of the guys on the Haynes forum has done though, it's adjustable and the pedals don't flex.
https://drive.google.com/file/d/0B-iOekLVikV5TWdrUEhtZjZHalk/view
jossey
posted on 28/7/15 at 08:57 PM Reply With Quote
Depends on how big ye feet are. Trim out the pedal box and move as far left as possible.
The Avon footwell is not very big. Mine is a bit tight to drive.
David Johnson
locost7-online.com
posted on 28/7/15 at 09:03 PM Reply With Quote
I have opened out the footwell a bit, as I'm using the bike engine, I've got around 335mm total width now, I'm going to fab the pedal box as wide as I can and space the pedals out as much as I can
CosKev3
posted on 28/7/15 at 09:29 PM Reply With Quote
You will need pedal stops for the clutch and throttle, as the bike ones don't need the full pedal travel.
