Author: Subject: AN6 BIG ENOUGH FOR OIL LINES? ZZR1200
teegray19
posted on 15/10/17 at 06:58 PM Reply With Quote
Evening All,
Ive recently swapped out a zzr1100 engine for the bigger zzr1200 engine, the engine swap is going fine but need some advise on the AN connections I've bought to swap out the OEM oil cooling system.
Ive gone for AN6 as I THOUGHT 5/16" bore would be enough...
whats everyones thoughts?
I've spent about £100 for fittings and pipe and don't want the chew to have to return it all and order in AN8 if its going to be OK.
AN6 for oil lines to cooler?
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
jossey
posted on 15/10/17 at 07:08 PM Reply With Quote
Hi mate I used an8 but I've seen 6 used on the cbr I had after the zzr u sold you. Hope all is well.
David Johnson
teegray19
posted on 15/10/17 at 07:37 PM Reply With Quote
All is well thanks, yeah AN8 looks like a better bet - but the std lines on the Z are 7mm connections and 9mm bore line.
AN6 is 6mm connections and 8mm bore lines.
don't want to restrict flow or pressure either though....
CosKev3
posted on 15/10/17 at 08:34 PM Reply With Quote
My R1 didn't have a cooler as standard,I used 1/2 BSP iirc,not had any pressure issues so going large is fine!
jossey
posted on 16/10/17 at 04:27 PM Reply With Quote
Maybe ok then but for me oil temp was a huge issue so anything I could do to increase flow would have helped temps. Why not test it for a while and watch temps etc. If you have it all to test.
David Johnson
