Mike01
posted on 16/4/22 at 04:42 PM |
Which build?
Hello everyone
I've lurked on here for some time , enjoying all the builds and finished car photos 🙂 and thought it about time I dipped my toe in
the water (so to speak) I've had the 1st edition of "build your own sports car" by Ron Champion for some time (a gift some 15 years
ago) but I'm reading mixed information on converting this chassis type to accept the more common mx5 donor, and while I don't mind a bit of
extra work and head scratching I'm not sure the effort would be worth it? Would I be better off parking that Ron Champion book and trying to get
a copy of the Chris Gibbs book?
ianhurley20
| posted on 17/4/22 at 08:23 AM |
I built the Chris Gibbs/ Martin Kienan version and thought it was a much better machine. Independant rear end (Sierra or MX5 based), 100mm wider
(which adds a lot of comfort and elbow room) being some of the main advantages. If you do a google search for the RC / MK book on google there is a
downloadable copy - shhh, don't tell anyone
Slimy38
| posted on 17/4/22 at 12:32 PM |
I have to admit going for a Ron Champion design with an MX5 donor is maybe a little more 'head scratching' than I would go for. Even the
Chris Gibbs book needs some imagination to get it working for the MX5.
As for trying to find a copy, it's only a couple of weeks until Stoneleigh, you are almost guaranteed to find a copy or two for sale.
Mike01
| posted on 8/5/23 at 10:04 AM |
So I have managed to get a copy of the Chris Gibbs book, and also have the Vodou and Mcsorley plans downloaded and printed out , and I've managed
to get hold of a MK1 mx5 engine/box/prop shaft so I have committed to the build 🙂 I do really like the original roadster look/size so am I
right in thinking the Mcsorley plans will best serve me ? Giving me the similar dimensions but the ability to mount the mx5 running gear? I also have
a question about the welder I have purchased but not sure which section to best place it under?
Slimy38
| posted on 8/5/23 at 10:27 AM |
You don't 'need' the Mcsorley increased size to cater for the MX5 rear end, it'll work with any of them. It is good if you need
the extra width though.
It might be worth getting the Saturn plans as well, they help with the rear end which is the biggest change for the MX5. The rear diff is very
different to most other diffs, the long mounting arms needs quite a different design.
For the welder question there is a tools section.
