Author: Subject: Minimum wiring required to run a MX5 on original ECU.
flange nut
posted on 2/12/22 at 02:36 PM Reply With Quote
Has anyone got details of the necessary wiring required to run an MX5 on it's original ECU? The car won't have the original instruments.
Many thanks.
Geoff
gremlin1234
posted on 2/12/22 at 07:12 PM Reply With Quote
would get it running with the original dash, then substitute/delete items later.
JAG
posted on 5/12/22 at 08:03 AM Reply With Quote
Which MX-5 engine are we talking about?
I built my car with a 1994 engine and it was easy to get that running on the standard ECU without instruments.
Later engines may be more tricksy
Justin
Rallychris
posted on 7/12/22 at 06:00 PM Reply With Quote
For Mk2/2.5 (NB) engines you will need the matched ECU, immobiliser box and chipped key, plus key reader from the ignition switch to have any hope of getting the engine to run on the standard ECU. The fuel pump and starter inhibit circuits can be bypassed from the immobiliser module, but the ECU won’t run the ignition (and injectors) without the right signal from immobiliser.
Robin Hood 2B Mazda Project Started March 2021
