I'm going to do a rear engine build as you probably know
But I have a few questions.....
Firstly, I'm planning on building a roll cage sort of setup, but using a windscreen area roll hoop and then twin parallel tube to the rear roll
bar, so it's still easy to get in (with a few braces
If I sva without windscreen can I then add one later on?
Planning on using a defender windscreen and cutting it down (although I do have a series land rover windscreen and surround I could modify to make it
smaller
And will plan to have a soft top and doors as such for wet weather, what's best approach to that and it be waterproof?
Originally posted by TurboLocostIf I sva without windscreen can I then add one later on?
