Ive order the donor pack from MK with the standard diff however:
1) Should I go for a limited diff? I am going to use it mainly on the roads
2) How much more expensive is an standard LSD
3) Is it an easy mod
The Haynes kit car maunal says not to bother with an LSD unless its a track car??
The sierra LSD is built into the same shell as the open diff so it is no harder to fit to the car than the open diff. You can only have an LSD with
the bolt on type half shafts rather than the push in shafts. It is not a problem but is about 10kg heavier, I'm told.
I have an LSD and I'm quite happy with it. Having never driven a similar car with an open diff, I can't say which is better.
i have lsd but its only because thats what i could lay my hands on when i was looking.
i have driven my uncles westi and theres not much in it to be honest
Isn't the sierra lsd too "heavy" for a seven, in the sense that it needs the force of a sierra to make it slip, so it tends to go
straight - inducing understeer and needing a good ol' heave-ho to turn in?
i could probably have worded that better
I think RGB Race with NON LSD's but only in the Blade cars (could be very wrong on that!), but since I Built a Blade car also - I figured I would
save the 10kilos and not bother! (I think the 10k saving is from diff and shafts together)
Have you started your kit already Paul? and whereabouts in Knutsford are you?
cheers and hth,
Steve.
Not started the build yet. I am supposed to pick up the donor kit this week and asked for an LSD. The guys at MK said that they were hard to find so
I wanted to know if they are worth it.
Steve : are you local to Knutsford then?
I'm only in Middlewich Paul and I've just finished so you can have a good look over the car if you are interested?
I could nip over to Knutsford and take you for a spin in my NON lsd if you like?
Steve.
Tell you what Paul - he's not as local as I am.....
Pop round for a decko at mine if you want - it's a proper locost, not a kit . . ;^)
Bob
Heres my two pence worth..........
IMHO an LSD isnt a necessity in a seven, but it makes for good fun ar5ing about drawing elevens and the like. Expect to pay more for an LSD second
hand as the 3.62 (LSD) was fitted to the XR4X4 and the Cossie, so it can therefore attract "cossie tax".
The diff itself is heavier than an open diff but the major weight difference is in the shafts as they are bolt on Lobro joints on the LSD as opposed
to push in on the open diff.
However, you can be cunning like me and fit regular push in shafts to the LSD just by removing the push in joint and fitting new Lobros at the diff
end. I have written a couple of threads about this as there are slight anomolies with splines from model to model which may scupper that plan.
The great bonus for me in doing this was it enabled me to fit drums which are perfectly good enough for a 7 and also (very slightly) lighter than the
rear disc setup. (I do however dislike the look of drums)
As for how well it works in a light car, its not a genuine slipper as youd find in a "proper" LSD, its a sealed viscous unit. Some have said
it can hook up quickly and cause problems but Ive yet to find any proof of that. Being viscous by nature, it should be progressive and in my
experience is just that.
If I was building a track car to be as light as pos, Id use an open diff, but for the extra weight, offset by swapping shafts, it wasnt worth it for
me.
Rgds
Richie
[Edited on 19/4/07 by RichieC]
Weights are as follows:
Standard Sierra 1.6 Diff - 18.5Kg
Standard Sierra 2.0 Diff - 20.5Kg
LSD Diff (Lobro type) - 24.5Kg
Half SHafts:
Standrad Sierra 1.6 (Push type) - 8Kg/Shaft
Standard Sierra 2.0 (Push Type) - 10Kg/shaft
LSD Shafts - didn't weigh them but I expect around 12Kg/shaft
These were all done on my bathroom scales but should give an indication. Total weight saving from te 1.6 to the LSD is around 14Kg.
Bob
we'll have to meet up soon enough!
thats when I've fixed my car after all the things that've just happened to it on the ride out tonight!!!
