Harness
Stuart_B - 29/1/08 at 05:56 PM
hi, what size are the bolts required for the harness??
If this did not make sense here is a picture.
sorry about the size.
theconrodkid - 29/1/08 at 06:11 PM
7/16 unf 8.8 min with the spec stamped on the head
BenB - 29/1/08 at 06:16 PM
Normally 7/16UNF. Some harnesses (Sabelts) use 8mm HT 12.9 bolts instead.
... but 99% 7/16 UNF as ^^^^^^^^
Stuart_B - 29/1/08 at 07:58 PM
Thank you, i wil see if i can get some if they do not come with the harness.
Stuart
zxrlocost - 29/1/08 at 09:47 PM
they will most likely come with three lines one the top this is the equivalent of 8.8
lotusmadandy - 30/1/08 at 11:48 AM
the threads are 7/16ths on the mk chassis
if you have trouble getting them,the seat belt bolts from your sierra donor car fit the threads and are 8.8 ton.
paulmw - 30/1/08 at 01:21 PM
I got some Willians harneses that only come with the top eye bolts.
I got some 7/16 bolts for the bottom from Tifosi today for £1.50 each. Give them a buzz 01769 581 454
Stuart_B - 30/1/08 at 01:36 PM
where are Tifosi located?
paulmw - 31/1/08 at 08:10 PM
Devon, me thinks
Stuart_B - 31/1/08 at 08:14 PM
Bit far for me.
