Can somebody please shed some light on the Yamaha R1 engine, of which my knowledge is limited to Wikipedia and the various model histories. I have
acquired a chassis with a 2006 engine (the last of the 20-valve series). It's not in a great state of health, but runs 'OK', having
withstood some serious abuse.
Someone out there must have replaced one of these units with the 2007-8 models, a more conventional 16-valve unit (with some entertaining inlet
trumpets). Are the 2007-8 units physically similar to the 2004-6 units, i.e. do I have to contemplate engine-mount relocation and/or
differential/sprocket relocation to fit (it's a md-engine chain drive set-up) - does it go straight in????
Apparently all is well:
http://www.locostbuilders.co.uk/viewthread.php?tid=96372
But it'd be reassuring to hear from others.
If it doesn't fit without hassle, then I'll probably try something else KawaSuki.
I guess if AB is reading this, he could possibly tempt me with something from Mr Honda for future reference. The injector/airbox height isn't an
issue with this thing (unlike some others).
I had an '07 R1 engine to put in my Global, but ended up selling it, as there were running issues unique to the Global race cars:-(
The information I was able to ascertain was the '07 block is a 5VY (not 100% sure if this applies to the '08), the same as the 04-06 engine,
but the head is 16v, marked 4c8. So with that in mind, the theory is that certainly an 07 should the same as an 04-06, as the mounts would be the
same (unless anyone knows different).
Hope this is of some help
Ian
