Where can i get some and how much?
try rallydesign
http://www.rallydesign.co.uk/catalog/default.php
about £60 +vat each
Being pedantic - the Sierra never had Alloy rear calipers. They were cast Iron.
Those from Rally Design were designed for a VW vehicle. What caliper bore size are they??
I think Hispec has finally released their Sierra rear brake set up. I see that Fisher Sportscars/The Kit Car Workshop have them listed in their Ebay
shop.
I know that, otherwise i could just go to Ford and get some!!! Lol!!
Are those HiSpec ones for front or rear?
[Edited on 16/1/06 by R1minimagic]
I am fiting the rally design ones as the hispec ones bend the disk alledgedlly...
Why not use Citroen/Peugeot alloy rear calipers.
I have a pair of the rally design calipers for sale
as I have had to change plans as they dont fit under 13" rims
I can send them back to rally design so make a sensible offer if you want them
Lee
Originally posted by cossey
if the disk was very hot and the hand brake was put on as it might warp the disc
they wont bend the disk that much if the hand brake is properly sorted as the force needed to stop a light locost or other kitcar from moving will be fairly low and the disks are very stiff esp if using vented disks. the only time there would be a problem is if the disk was very hot and the hand brake was put on as it might warp the disk but even normal handbrakes and hot disks are a bad idea.
wilwood are now doing a ali 4 pot with handbrake.
rally design sell them
http://www.rallydesign.co.uk/catalog/product_info.php?manufacturers_id=45&products_id=11370
Tony.
Tony.
Thats what I am fitting on my car... they are £119+vat
That's why I wince when I see people at traffic lights with their brake lights on rather than using the hand brake. The foot brake will warp all 4 discs whereas the handbrake only does in the rears.
