hi there
would an cbr 600 engine from an 1986 bike be any good in an mk indy?
thanks stuart
hi no
ok
thanks
ill keep on looking then
what do you suggest?
I think if it has a chain drive it would not be suitable. It looks like only shaft outputs can be used in a front engined 7.
You could instead do a nice little single seater.
hi any sports bike over 900cc with power over 125bhp
thanks for advice
I thought most of the common engines were from chain driven bikes (Blade, R1, ZX10 etc). Don't you just replace the sprocket with a suitable flange to attach the prop shaft?
[Well if that was the case I'd have expected to see the cars with the engine fitted sideways but so far I've only noticed ones that were in line.
One CBR600 engine wouldnt be enough, but two might be
CBR6s have 100bhp but quite a small amount of torque.
You could use them in something very light as some of the Formula Student racers do to great effect but they are a little too peaky in their power
delivery and low on torque for a 7 imho.
Best off to to use something more like a 1 litre engine from a sports bike or sports tourer - but thats a nother story.
Whippy - the vast majority of bike engines are chain drive and in order to run a propshaft for a RWD 7 style car a sprocket adaptor is used. This
bolts to the splined output shaft where the front sprocket would have been on the bike and gives a common prop flange PCD for mounting to a custom
prop.
Obviously the bike engine is turned through 90 degrees so that this moutning face points backwards towards the diff.
Take a look at the next car show or perhaps someone will post a pic?
It is the torque that is the greatest negative (some of the modern 600's are in excess of 130 Hp)
Stick to your "litre" category bikes!
R1 engine showing prop adaptor position.
ohhhh I see, I think I was getting mixed up with the chain direction.
Actually I think your arrow needs moving down a bit but we get the idea
Like your trumpets BTW
Yeah, Steve's right!
The arrow was added yonks ago for some other reason and I can't for the life of me remember why....
And don't just look at the trumpets - have a good squint at the carbs. What you have there is a set of Keihin FCR41 flat slides. If Carlsberg
made carbs those would be them! Retailing at around £1000 + VAT.
I thank you...
OOOOOOOO I like
So actually the arrow was to highlight your nice carbs then
PS What happened to Mr Whippy??
Then you'd have about as much power and torque as a carb'd R1, but with nearly double the weight.
If your looking for budget don't forget the older engines.
Mine is Suzuki RF900 claimed 118bhp
others like:-
Yamaha FZR1000's
Kawazaki GPZ's
Honda CBR1000's
all got over 100bhp
big bonus is pre '95 no CAT required.
Cheap ones can be found but risk of being knackered.
Both my RF900's had duff 2nd gears, but fix one my self. both ran well.
But I would more than cry if I had a Busa go bang.
Wot about a GSXR 1100 motor from the oil/air cooled models? They had heaps of grunt and would be cheap as doorstops now. You just need some decent
airflow.
PS Don't forget GixxerKart!
thanks for advice ok ill have to decide what to get all i know is i have to get rid of my dohc engine,
which engine is easiest for an novice to install and get running?
and preferably cheaper
thanks
OOOOOOOO I like
