Aaaah SVA next Tuesday 17th
andyharding - 12/1/06 at 11:21 AM
A bit quicker than expected. Haven't finished the car yet alone SVA proofed it.
Does anyone have any bolt covers and front suspension covers they want to sell/rent me?
I'll post some photos later for some words of wisdom!
jos - 12/1/06 at 11:38 AM
Yup, what do you need. I can drop them over if you like
Paul G - 12/1/06 at 11:41 AM
Hi Andy whereabouts in Staffs are you? I'm in Stoke, just waiting for my SVA date to come through now (I'm hoping around the beginning of next month...)
Paul
DarrenW - 12/1/06 at 11:48 AM
Good luck with the test.
To cover steering arms i used split conduit and secured with cable ties (cut ends to the back).
To cover shocker height adjust nut i secured round conduit just below the nut (cut a length just right length and passed cable tie thro it then wrapped around shocker) and for good measure wrapped some seat belt around the nut twice and secured with cable tie.
Nuts and rebound adjust knob all covered with normal nut covers.
Above all enjoy it. I think a good aim is to minimise fail points. Id recommend concentrating on main areas first (cable / pipe runs, brakes, everything tight and working, electrics etc). After that you will only get a pissy little nit picky list of jobs that shouldt present too many problems.
phillippe - 12/1/06 at 05:50 PM
good luck pal....
andyharding - 12/1/06 at 07:38 PM
Pre SVA Prep 1
Pre SVA Prep 1
[img]/upload/IMG_9925.jpg[/img]
[img]/upload/IMG_9926.jpg[/img]
[img]/upload/IMG_9927.jpg[/img]
[img]/upload/IMG_9928.jpg[/img]
[img]/upload/IMG_9929.jpg[/img]
[img]/upload/IMG_9930.jpg[/img]
[img]/upload/IMG_9931.jpg[/img]
[img]/upload/IMG_9934.jpg[/img]
[Edited on 12/1/06 by andyharding]
andyharding - 12/1/06 at 07:48 PM
Todo list:-
Interior:-
+ Cover edges of side panels with pipe insulation
+ Cover edges of tunnel prob. with cut pipe insulation
+ Make cowel for steering column (don't think I need to do this though)
+ Gear level + handbrake gaitors (are these needed?)
+ Pedel non-slip
+ Pad steering wheel
Front suspension:-
+ Bolt covers for top wishbone front mounting, shock top and bottom mount, shock adjuster, hub bolt.
+ Cover track rods
+ Cover spring platform
+ Headlamp mounting spare thread cover with split heater hose
+ Extend indicators (any quick solutions?)
Don't think anything else needs doing as a 100mm radius can't touch it.
Boot cover will be made of 6mm ply and covered in the blue leather so the edge is soft. Screwed on with pan head self tappers. (not having a boot will fit cargo nets behind seats)
Will cable ties on the CV joints fail? I've heard it won't pass an MOT which is mad as the supplied metal clamps wouldn't keep them on but the ties will.
andyharding - 12/1/06 at 07:49 PM
The only things I have are some edge beading. Can you look at the photos and let me know if you have anything suitable? Many thanks!
andyharding - 12/1/06 at 07:50 PM
Paul
Werrington, Stoke on Trent. How about you?
You're welcome around sometime!
andyharding - 12/1/06 at 07:52 PM
All electrics work fine (apart from sodding horn due to crappy Mountney boss. Will fix. All brake pipes secured about every 6" with P clips. Cabling and fuel pipe about every 10". Only the main +ve from the battery to the starter that isn't clipped.
TBH not expecting a pass first time but the less I fail on the less I need to fix quickly before a re-test. Insurance only give me a few weeks to get in Reg'd.
andyharding - 12/1/06 at 07:54 PM
Sods law!
One of the core plugs has started dripping and meased up my nice paint job. There is no way I can fix it without yanking the engine.
Will this be a prob? It's not leaking enough to drain the coolant. Just a drip...
I love speed :-P - 12/1/06 at 08:09 PM
good luck
oliwb - 12/1/06 at 08:34 PM
Looks like you might need some edging trim on the cycle wings.....don't think they can fail you on a small leak from a core plug....are you trailering the car there or driving?? Oli.
jos - 12/1/06 at 10:09 PM
First pic
I would cover the upper suspension arm to ball joint nut, the upper suspension arm to cvhassis bolt head
the steering rack to track rod end nut, both suspension strut bolt heads, and i'd also check the distance of the front indicator from the side of the vehicle.
Second pic
Id fit a gaiter around the gear stick and the ally pannel with u trim. I'd also enclose the steering column & ignition barrel with a simple piece of fabric (grey area with exemption zone). I cant see if youve got a handbrake gaiter but you'll probably need one if you dont.
Third pic
I'd replace the mountney steering wheel with a sierra one. It increase the exemption zone and also doesnt have any exposed metal for mr examiner to be unhappy with. Have you checked whether your front braided hoses touch any bodywork on full lock, on both sides???. I might alos be tempted to put u trim around the exhaust cut out and air filter hole in the bonnet. Have you checked the exhaust clamp and also for sharp edges on the exhaust surface.
Fourth pic
Nice use of garden hose.
Fifth pic
Ditto - I would change anything but would take some conduit just incase garden hose isnt to the examiners liking
Sixth pic
Personally I'd try to get some conduit over the pair of blue wires, and the red and green wires and also try to secure them to stop flappage.
Seventh pic.
Check the top of the cam belt doesnt score the bonnet
Eighth pic
Personally I zip tied the HT leads together progressively as your ht lead to cyl 4 looks like its touching the exhaust header. You can take up the slack using zip ties.
Just checking through your list and youve got most of my points. I'll check you location and bring over my SVA box of bits if possible.
DarrenW had a core plug let go at his SVA retest. Pick his brain on what he did. Personally I'd postpone if I though it would let go on the day of the test. You should have to pay again and reclaim as youre giving over 24 hours.
andyharding - 12/1/06 at 10:40 PM
I read something about the edges of fiber re-enforced panels just needing the edges blunted but I'll stick some trim on the be safe.
Driving there!
andyharding - 12/1/06 at 10:41 PM
That would be great, thanks!
I confident the core plug won't let go, it's just seeping and my fan works well so it won't overheat. Famous last words!
Hornet - 13/1/06 at 07:59 AM
Hi dude.. You will need a cover on the +ve terminal of battery prob.
Best of Luck.
jos - 13/1/06 at 08:46 AM
When do you want me and could you u2u me your post code & house number. Ive u2u'd you my mobile no.
andyharding - 13/1/06 at 10:22 AM
Thanks for the help so far. Gives a lot to get through this weekend!
Haven't got the Sierra wheel so I've ordered the padded cover from Europa.
DarrenW - 13/1/06 at 11:20 AM
Originally posted by andyharding
Sods law!
Core plug - Dont panic.
First question - is it leaking from edge or due to being corroded from inside out? If due to corrosion (this happens when old engines are stored without fluids for 1 year plus) then this happened to me at the test.
is it easy to get to? My rear pinto core plug failed at SVA. i dumped a large quantity of rusty sh1tty looking water into the brake rollers at the retest. Luckily that was last part of test and passed.
Rear core plugs are a pig to get to - i had to split engine and box.
Temp fix as follows - clean up as best as possible to remove rust. Ensure dust and grease free. Fill core plug with JB weld. I layerd mine in in 2 or 3 goes. Last layer proud of plug and onto block. In this weather it needs some gentle heat to get it to go off. I used small Asda fan heater on setting 1. JB weld runs on vertical surfaces before hardening so i held it in place with gaffer tape. After curing over night i filled with water and coolant - no more leaks. I then fired her up a few times progressively letting it get hotter each time and then cooling back down. This helps it to cure even better from the inside. After i was happy with that i let it get up to fan kicking in temp a few times. Touch wood mine has held up ok although only done 100 freezing cold miles so far.
As always - no warranty implied or given with this fix but it has worked for me so far. I was told about it by a garage who has had similar success.
If core plug is leaking from between plug and block then i dont know if this will work. If it is due to corrosion then it is fair bet that others are on way out as well so would be well to consider replacement in the near future.
HTH,
Darren.
andyharding - 14/1/06 at 06:42 PM
Big thanks to Jos who kindly dropped off his SVA box today.
I'll post some picks tomorrow for your critisisms of my SVA proofing...
andyharding - 16/1/06 at 05:10 PM
Oh poo
jos - 17/1/06 at 08:13 AM
Well, how did you get on then???
scutter - 17/1/06 at 08:29 AM
Good luck fella, Jos let the bloke get there first.
ATB Dan.
jos - 17/1/06 at 09:15 AM
He's been there 13 minutes
scutter - 17/1/06 at 11:40 AM
LOL
ATB Dan
andyharding - 17/1/06 at 02:09 PM
Fail but only 1/2 page:-
1) Dash radius, will use covered pipe lagging to pad.
2) Under dash chassis rail needs padding as above.
3) Pipe lagging used in interior needs covering. Expected that.
4) Headlamp aim.
5) 4 exterior projections missed. Simple fix.
6) Wheels don't fit within body plan. Will fit old Sierra wheels.
7) Fuel pipe needs insulating where it contacts manifold to stop it rubbing through.
8) Front tyre touches U trim on wing. Will be solved by fitting Sierra wheels.
9) Self centering. Only just failed on this. Sierra wheels will hopefully scrape through.
Overall he said it was a very good build and way above average. I'm pretty pleased really.
P.S. could have fixed all of this there but didn't have the Sierra wheels with me so thought I might as well do it at home and go back.
[Edited on 17/1/06 by andyharding]
jos - 17/1/06 at 02:19 PM
Very well done, should be ready for registration by the end of the week, theyre not that busy
phillippe - 17/1/06 at 02:29 PM
its not bad at leest u now wot u got to do now im all done and its a bloody good feeling Rescued attachment all done yepeeee 010.jpg
Paul G - 17/1/06 at 04:35 PM
Well done! all sound straight forward enough fixes - which SVA centre did you go to?
Paul
jos - 17/1/06 at 04:45 PM
Will you organise for Mr DVLA to attend VOSA on the day of your retest??
[Edited on 17/1/06 by jos]
Simon - 17/1/06 at 08:05 PM
Andy,
That's a "good" fail - all minor, easily rectifiable points, should have them all done by now
Keep us informed of retest!
Simon
andyharding - 17/1/06 at 08:13 PM
Shrewsbury
Paul
Yes, re-test is next Tuesday at 13.00. DVLA are meeting me there at 14.00.
bigrich - 22/1/06 at 09:45 PM
good luck for tuesday hope all goes well
jos - 24/1/06 at 04:30 PM
How did the retest go
How was the drive home???? Did you stop to warm up??
andyharding - 24/1/06 at 05:42 PM
Passed
Thanks to everyone who helped, especially Jos!
Got an age related reg (G) and had some plates made up on the way home.
Put myh hood up and 2 pairs of gloves on for the drive back. Much warmer!
phillippe - 24/1/06 at 07:44 PM
well done
Mark Allanson - 24/1/06 at 08:22 PM
Excellent news
Simon - 24/1/06 at 09:11 PM
Good show
How many is that for the year - all three weeks of it?
Simon
jos - 25/1/06 at 08:07 AM
Nice one well done Andy. You did look mighty cold at the retest.
Paul G - 25/1/06 at 10:03 AM
Nice one matey bet you're well chuffed, I'll have to pop round and get some tips for my upcoming SVA !
andyharding - 25/1/06 at 12:44 PM
Thanks guys!
A few pics to inspire those who are nearly there:-
Post SVA 1
Post SVA 1
Post SVA 2
Post SVA 2
Post SVA 3
Post SVA 3
Post SVA 4
Post SVA 4
Post SVA 5
Post SVA 5
jos - 25/1/06 at 01:45 PM
Cor those mechanics changed your wheels quick enough
Dave J - 25/1/06 at 03:58 PM
Very well done, looks a fine build
All the best,
Dave
flak monkey - 25/1/06 at 04:09 PM
Well done indeed!
Car looks fantastic! Hope it brings you loads of fun!
Danozeman - 25/1/06 at 09:18 PM
Very well done mate. LOoks a fine build indeed. The white and silver go well together.
