Can anyone explain the advantages / disadvantages of using oval tube for front wishbones please!
Ta muchly!
Areodynamic ?
bling
Welll Dohhh! it's to make oneself more attractive to Wimmin. Everybody Knows that!
Advantages are because the load in the wishbones are front to back under braking etc... Oval tube is stronger horizontally....
Oval is more aero
Disadvantages - Cost, Harder to fabricate with.
Oval or flat oval tube stood vertical is strong but in used as wishbone material it is used horizontal which makes it weaker than round tube. So in
short use flat oval and have weaker wishbones by design.
[Edited on 25/10/11 by Talon Motorsport]
Oval is more aero
Oval tube is not weaker than round, it is actually stiffer & stronger than round tube of the same cross-section height it is however less
structurally efficient .
That is a round tube with equivalent bending stiffness would be lighter.
Hi Phil,
Without wishing to be rude, race car designers that choose to use oval tube come from highly educated backgrounds with masses of experience.
Its quite easy to prove that the principle loads in a wishbone will be in the horizontal plane.
If you take the example of a top wishbone there is no vertical load because there is nothing to restrain it from moving vertically.
On a lower wishbone you have the damper load trying to bend the tube that is true, but on say an F1 car that load will be fed so far outboard as to
avoid any significant bending load in the wishbone, yet they still will use and always have an oval tube, because what you get is the load caused by
the braking forces.
The braking load will be many times higher than the damper load. The damper load is the weight of the wheel, upright etc multiplied by hitting the
kerb etc. So this is a fairly lightweight assembly. With braking you have a much larger mass (corner weight of the whole car) being restrained by the
wishbone legs.
Cars have had strain gauges used to determine the actual loads. You'll find the above is true, its datalogged values.
It is unusual to find a common design principle used so commonly without it being for a reason. It comes from the fact that the real engineers who
first concieved it do know a thing or two.
[Edited on 25/10/11 by eddie99]
Hi Phil,
On a lower wishbone you have the damper load trying to bend the tube that is true, but on say an F1 car that load will be fed so far outboard as to avoid any significant bending load in the wishbone, yet they still will use and always have an oval tube, because what you get is the load caused by the braking forces.
The braking load will be many times higher than the damper load. The damper load is the weight of the wheel, upright etc multiplied by hitting the kerb etc. So this is a fairly lightweight assembly. With braking you have a much larger mass (corner weight of the whole car) being restrained by the wishbone legs.
It is unusual to find a common design principle used so commonly without it being for a reason. It comes from the fact that the real engineers who first concieved it do know a thing or two.
Hi
I think the trouble here is that " Talon motorsport " use a wishbone design where the damper sits so far inboard from the upright that its
ridiculous. So in his circumstances he would need a much stronger design to cope with the loads.
Cheers Matt
I just thought it was very cheap from Tesco's on the bottom of shopping trolleys
Caber
Originally posted by procomp
Hi
I think the trouble here is that " Talon motorsport " use a wishbone design where the damper sits so far inboard from the upright that its ridiculous. So in his circumstances he would need a much stronger design to cope with the loads.
Cheers Matt
That tube in the pics should not be anywhere near a Locost or any other cars wishbones.
It is NOT what is used in racecars, at least not at the level I see. Proper racecar Oval Tube is rolled from round, and is true oval/ellipse, and
seamless. Only available in CrMo as far as I'm aware, which causes problems of its own to the unaware and home fabricator.
That Flat Sided Oval, as it is sold by stockists, is seamed and fairly soft rubbish, and meant for furniture or supermarket trolleys. Dangerous to be
halfway polite. But, use the thicker wall stuff and you will probably get away with it, albeit with wishbones that would do justice to a NASCAR dirt
tracker.( And even they use Seamless or DOM mechanical.) You won't need springs, just attach them solid and watch them bend!
Nev.
And BT, you've been asked too many times to stop giving the impression you are an engineer! Stop talking a load of , er...ah... bovine animal
derived organic fertiliser!
[Edited on 26/10/11 by Neville Jones]
Captain Insecure is at it again, funny thing but has anybody else noticed that Neville Jones rarely contributes anything constructive to a
discussion?
Did I post anything that that was incorrect ? as anybody who actually understands framed structures and the properties of structural sections
will confirm I didn't.
I also stayed on topic didn't divert the thread into smoke screen discussion on the weld-ability of chrome alloy steels.
In future remember about 40% of posters on this forum probably have some sort of engineering related qualification, perhaps as many as 20% might
have HNC/HND or higher perhaps 10% have a 2.1 or higher Honours Degree in an engineering related subject and a few might have a Phd. Out of that
lot we have a lot of specialised knowledge.
Thanks for the input guys... Just thought I'd ask as I saw it advertised by ADR Engineering for what I thought was reasonable money....
Linky
Personally I don't like the look of it for wishbones at all. Not from a technical perspective, purely aesthetic, a well fabricated round tube construction just looks better to me.
Hi Phil,
According to this guy on Pistonheads there's another advantage that we seem to have overlooked...
Quote-" One of the details I love about the CGT is that the lower rear wishbones are aerodynamically shaped to aid downforce. "
Downforce... dubious (nice idea though). Drag reduction, maybe with aero section, not really with oval.
Hi
Having used this tubing for the last 15 years for lower wishbones ( correctly designed ) it has proved to be very useful to enable the braking forces
to be controlled whilst still giving the weak link to save chassis damage during accident damage. Although the sizes listed above are too weak for the
application. The 32 x 16 x 2mm wall is more suited to the application.
Where it has gained a bad reputation is from where manufacturers such as MNR MK Mac#1 and now the Haynes chassis have indeed placed there damper
mounting in a rather silly position quite some distance inboard from the ball joint rather than a more suitable position far closer to the ball joint.
I have yet too see a properly engineered wishbone using this material have any problem what so ever. For the top wishbones the tubing was available in
25 x 15 x 2mm but this was found to be to strong and led to the chassis taking too much load during accidents so was dropped in favour of a round 19 x
1.6mm. However when required for bling i just get friends at SPA to make either the true oval as mentioned above or the teardrop ( aero ) as supplied
a lot of the race part manufacturers.
If anyone has concerns about it's use on their kit just stick a straight edge under the wishbone legs on a regular basis and check for a bend.
Possibly worth while on kits from the manufacturers listed above.
Cheers Matt
Cheers Matt
[img]http://i156.photobucket.com/albums/t39/stefaneinz/CGT%20detail]
