Is depowering a PAS rack acceptable to MOT/IVA?
Yes, we usually keep fluid in and join the pipes together
There's a detailed explanation on how to remove the pas from the mx5 rack in the Midlana book.
I'm a bit suspicious at the moment whether this will be acceptable for IVA.
It tells how to remove the central seal and take away all the pas fittings but leaves the input covered in holes... I've plugged the big ones so
far (mainly to keep dirt out)
There's a pic in my Midlana thread....
Iffy in my experience, my dad a MK2 golf with de-ac PAS which failed on it.
Wording is if its standard fit it should not be deactivated, but if it was an option then it can be.
[Edited on 30-7-15 by loggyboy]
I de powered my rack - by fitting a genuine manual rack. Did this because concerned about IVA.
My midlana book arrived yesterday, oddly enough. Might press on with the de powered Pas rack for now . if I need a manual rack then I can source
one. Crap thing is I gave a mk1 mx5 manual steering rack away when I stripped the car
If you use a PAS rack without the assistance you have introduced a torsion spring into the steering column, just what you don't want for precision steering.
Would that also be the case for speed-sensitive electronically-assisted racks (thinking specifically about the Smart Roadster rack).
Thanks Mike.
The ForTwo rack may very well be the same... will look into.
