It is with great sadness and due to an increased workload that I am advertising my MNR ‘Un started’ kit car project.
****£4500****ono PM, Call or text 07894833925
Collected July 2009 this kit car has only had the 2 bulkhead panels fitted and is ‘as new’ ready for the new owner to complete whilst making a
significant saving over the cost price.
MNR are by far the leading kit car manufacturer at present with a high quality of parts and unrivalled customer service. I have spoken to MNR prior to
sale who have ensured me that they will gladly be on hand to assist the buyer in completing this project and providing further support where required.
This kit includes the latest style nose cone for improved cooling.
Having paid >£6000 for all of the items listed below this represents a huge saving over the regular kit price, engine and sundries cost.
I am located in Lincoln and any potential purchaser is more than welcome to come and view the kit prior to purchase/bidding. It really is worth coming
to see just how well made the chassis and components are compared to other manufacturers.
I have managed to put some picture on the link below. I will be listing this item on ebay (Item No 280447469112) once the weather improves to give
people more of a chance to view, hopefully when the snow leaves!!
http://s640.photobucket.com/albums/uu125/GeoffMM/MNR%20VortX%20R1%20Kit/
Delivery can be arranged at a cost of £120 but full payment for the kit and delivery will be required first as I will have to hire a van and take a
day off work etc.
These items have been bought in addition to the basic kit supplied by MNR.
1 x 2008 Yamaha R1 engine and wiring
loom – Supplied by Yorkshire engines.
Custom manifold to fit R1 engine and MNR chassis.
3.62 Refurbished Differential as advised by MNR to suit above engine application.
Custom MNR kit wiring loom for all ancillaries and lighting, dials etc.
Side impact protection bars.
Upper and lower custom coolant hoses complete with high pressure blue hose connectors.
MNR powder coated round tubular chassis complete with 2008 R1 engine cradle, engine / gearbox mountings, Fitted and bonded front barley seed pattern
floor pan and rear polished floor pans, Standard rac approved integral rollcage made from T45 tube, Integral 4 point seat belt fixings, MNR Powder
Coated Suspension Set,
FRONT TOP WISHBONE SET comprising of, 2 X FRONT TOP WISHBONES STRAIGHT BOSS TAKES 1/2 UNF RODEND, 4 X 7/16 UNF RODENDS, 4 X 7/16 UNF RIGHT HAND
LOCKNUTS, 2 X 1/2 UNF RODENDS, 2 X 1/2 UNF RIGHT HAND LOCKNUTS, 2 X 1/2 UNF LARGE WASHERS, 2 X THREADED CAMBER ADJUSTERS LONG 1/2 UNF THREAD, 4 X 7/16
UNF X 3 INCH BOLTS, 4 X 7/16 UNF NYLOCS, 16 X 7/16 WASHERS, 8 X 7/16 UNF SIDESPACERS, FRONT LOWER WISHBONE SET, 2 X FRONT LOWER WISHBONES WELD IN
UNIBALL TYPE, 4 X 7/16 UNF RODENDS, 4 X 7/16 UNF RIGHT HAND LOCKNUTS, 2 X UNIBALLS FOR LOWER WISHBONE, 2 X RETAINING CIRCLIPS FOR UNIBALL, 2 X 1/2 UNF
X 4 INCH BOLTS FOR BOTTOM PUSH ROD LOCATION, 2 X 1/2 UNF NYLOCS FOR BOTTOM PUSH ROD LOCATION, 4 X 1/2 UNF WASHERS FOR BOTTOM PUSH ROD LOCATION, 4 X
7/16 UNF X 3 INCH BOLTS, 4 X 7/16 UNF NYLOCS, 36 X 7/16 WASHERS, 8 X 7/16 UNF SIDESPACERS, REAR LOWER WISHBONES, 2 X REAR LOWER WISHBONES, 8 X 7/16
UNF R/H ROD ENDS, 8 X 7/16 UNF LOCKNUTS, 12 X 7/16 UNF SIDESPACERS, 4 X 7/16 UNF X 3 INCH BOLTS, 4 X 7/16 UNF NYLOCS, 36 X 7/16 WASHERS, REAR TOP
WISHBONES, 2X REAR TOP WISHBONES, 4 X 7/16 UNF RODENDS, 4 X 7/16 UNF RIGHT HAND LOCKNUTS, 2X THREADED CAMBER ADJUSTERS 1/2 UNF THREAD, 2 X 1/2 UNF R/H
ROD ENDS, 2 X M12 LARGE WASHERS, 2 X 1/2 UNF LOCK NUTS-RH, 4 X 7/16 UNF X 3 INCH BOLTS, 4 X 7/16 UNF NYLOCS, 36 X 7/16 WASHERS, 8 X 7/16 UNF
SIDESPACERS
REAR UPRIGHT PARTS comprising of, 2X REAR UPRIGHTS TAPPED-HANDED, 2X 1/2 UNF X 4 INCH BOLTS, 2X 1/2 UNF NYLOCKS, 4 X 1/2 UNF SIDE SPACERS, 20 X 1/2
UNF WASHERS, 4 X 7/16 UNF X 1 1/2 INCH BOLTS, 8 x m10 x 30 CAPHEAD BOLTS FOR BEARING TO REAR UPRIGHT FIXING
STEERING PARTS comprising of, 2 X M12 NYLOCKS FOR RACK BODY FIXING, 4X M12 WASHERS FOR RACK BODY FIXING, 2 X M12 X 70MM HEX BOLTS FOR RACK BODY
FIXING, 2 X M8 X 40 BOLTS FOR STEERING LINK FIXING, 2 X M8 NYLOCS FOR STEERING LINK FIXING, 4 X M8 WASHERS FOR STEERING LINK FIXING, 1X STEERING
COLUMN TO RACK LINK, 1X STEERING COLUMN BUSH SET, 2 X M10 X 50 BOLTS, 4 X M10 LARGE WASHERS, 2 X M10 NYLOCS, 1X MODIFIED RACK BODY, 1X RACK PINION, 1X
RACK PINION CONTAINER, 1 X SHORTENED QUICKRACK SHAFT, 2X STEERING RACK EXTENSIONS, 2X STEERING ARMS FROM DONOR RACK, 2X SIERRA TRACK ROD ENDS1XLH
1XRH-3368/9, 2X M10 X1 NYLOCKS FOR TRACKROD ENDS, 2 X STEERING RACK BOOTS, 2 X M12 X 60 SET SCREWS TO MOUNT COLUMN TO CHASSIS, 2 X M12 NYLOCS TO MOUNT
COLUMN TO CHASSIS, 4 X M12 WASHERS TO MOUNT STEERING COLUMN TO CHASSIS,
SHOCKER PARTS comprising of, 6 X 1/2 UNF X 3 INCH BOLTS, 6 X 1/2 UNF NYLOCS, 48 X 1/2 UNF WASHERS, 12 X 1/2 UNF SIDESPACERS, 2 X ALLOY BILLET ROCKERS,
4 X CUP BEARINGS FOR ROCKERS, 4 X THRUST BEARINGS FOR ROCKERS, 8 X THRUST BEARING WASHERS FOR ROCKERS, 2 X M12 X 75 BOLTS FOR ROCKER MOUNTING, 2 X M12
NYLOCS FOR ROCKER MOUNTING, 4 X M12 WASHERS FOR ROCKER MOUNTING, 2 X PUSHRODS, 2 X 1/2 UNF RIGHT HAND ROSEJOINTS, 2 X 1/2 UNF RIGHT HAND ROSEJOINT
LOCKNUTS, 2 X 1/2 UNF LEFT HAND ROSEJOINTS, 2 X 1/2 UNF LEFT HAND ROSEJOINT LOCKNUTS
FUEL PARTS comprising of, 40 X 5 MIL SHORT RIVETS FOR FUEL, 1 X COPPER FUEL LINE OR X2 IF FUEL INJECTED, 2 X 18 INCH RUBBER FUEL HOSE X 4 IF FUEL
INJECTED, 4 X JUBILEE CLIPS-FOR FUEL LINE 11-16 X 8 IF FUEL INJECTED, 25 X 3/8 INCH P CLIPS
ENGINE MOUNTINGS comprising of, 1 X ENGINE CRADLE for Yamaha R1 inc CORNER BOLTS, 1 X ENGINE BOLTS KIT
BODY FITTINGS comprising of, 1 X C/F BOOT COVER, 2 X INNER C/F SIDE PANELS, 1 X INNER C/F BACK PANEL, 20 X BLACK NO. PLATE SCREWS FOR BOOT COVER, 2 X
ALLOY FOOTWELL PANELS, 30 X 3.2MM RIVETS FOR FOOTWELL PANELS, 1 X ALLOY SCUTTLE PANEL PEDAL COVER, 50 X 3.2MM RIVETTS FOR SCUTTLE PANEL COVER, 2 X
NUMERPLATE SCREWS BLACK FOR PEDAL COVER, 1 X TUBE OF BONDING AGENT FOR INTERIOR PANELS, 1X HEADLAMP BAR, 2 X M8 X40 BOLTS FOR HEADLAMP BAR, 2 X M8
NYLOCS FOR HEADLAMP BAR, 4 X M8 WASHERS FOR HEADLAMP BAR, 1 X PAIR CYCLE WING BRACKETS, 4 X 90 DEGREE CYCLE WING BRACKET ARMS, 4 X CYCLE WING BRACKET
SLEEVES, 8 X M5 X 40 BOLTS, 16 X M5 WASHERS, 8 X M5 NYLOCS
MNR Full Ten Piece Bodywork Set in Ral 2004 Orange with black mudguards,
BODYWORK, SIDE/REAR PANEL, 2X REAR ARCHES, 2 X 1.5 METRE STRIPS OF REAR WING PIPING, 14 X M5 X 20 BOLTS FOR REAR ARCHES, 14 X M5 NYLOCS FOR REAR
ARCHES, 28 X M5 WASHERS FOR REAR ARCHES, SCUTTLE PANEL, 4 X M8 X 20 BOLTS FOR SCUTTLE FIXING, 4 X M8 LARGE WASHERS FOR SCUTTLE FIXING, BONNET, NOSE
CONE, 4 X M8 X 20 BOLTS FOR NOSECONE FIXING, 4 X M8 LARGE WASHERS FOR NOSECONE FIXING, 4 X M8 NYLOCSW FOR NOSECONE FIXING, 2 X FRONT ARCHES, 4 X
NUMBER PLATE SCREWS FOR FRONT ARCHES, 1 X GRP ONE PIECE TUNNEL COVER, 4 X NUMBER PLATE SCREWS FOR TUNNEL FIXING,
BRAKE PARTS comprising of, BRAIDED HOSE SET-02 STANDARD, MASTER CYLINDER TO FRONT T PIECE PIPE, MASTER CYLINDER TO REAR T PIECE PIPE, 2X FRONT T
PIECE TO FLEXI PIPE, 2X REAR T PIECE TO FLEXI PIPE, 3 WAY T PIECE, 4 WAY T PIECE, 2 X M5 X 40 BOLTS FOR T -PIECE FIXING, 2 X M5 NYLOCS FOR T-PIECE
FIXING, 4 X M5 WASHERS FOR T-PIECE FIXING, BRAKE PRESSURE SWITCH, 50 X 3/16 P CLIPS FOR BRAKELINE FIXING, 50 X SMALL RIVETS-3.2 FOR BRAKELINE
FIXING.
1 x Full colour build manual.
[Edited on 5/1/10 by GeoffMM]
Now on ebay 280447469112
Proper link to it. I'm putting it in my watching but
don't get excited, it's only curiosity
[Edited on 8/1/10 by Peteff]
Lol thanks for the link.
Someone sent me a message saying i should put a pic up of the finished car which sounds like good advice.
Will do when i get home.
I would love to buy it. Really fancy building another, cracking cars.
Good luck with the sale.
ETA:- You could also put an advert on Pistonheads.
There was a part built Westy on there recently, sold in 3 days.
[Edited on 8/1/10 by stuart_g]
Oh right i will have to have a look and see about advertising on there. I am in no rush so will try 1 advert at a time that is paid for.
I will have a look and see the spec of that westfield and how much it sold for.
I can't believe how many questions i have had asking if certain parts are included after i spent 4 hours making out such a long list.
Not to worry i will keep an eye on the listings. It's an incredibly cheap way to start this high quality kit so i'm sure it won't hang
around long.
the westfield sold for about 4k IIRC.
Item is now sold.
Thanks for everyone's help and support. No doubt i will return once work eases up with another kit ready to go.
