Hi folks.
I have a sheet of Carbon Fibre, yep the proper stuff not a vinyl!
I bought it to do the rear boot/desk of my car but have changed direction and won't be using this. It's a sandwich / composite backing, so
CF on 1 side, thickness overall is 3mm.
the piece measures slightly larger than this 1030mm/470mm. I have knocked off 5 mm all round because there's the tiniest of marks on 1 edge, so
to avoid having someone disappointed i'd rather say it's slightly smaller than it actually is.
As those who have tried know, taking a piccie of a piece of CF isn't easy! Too far away and you get no detail, get too close and you get a lovely
reflection.....
I can tell you that this is unmarked - if it looks like there's a mark on it it would just be reflection/dust or whatever else it is perfect, it
arrived in oodles of bubble wrap and has been sitting safe indoors waiting to be used, its only fresh out of the packaging this morning to take the
piccies - for what they're worth!
Location is 10mins from the DFord Crossing/Sevenoaks/Brands - although i can rewrap and post, no idea what the cost would be, am assuming it would
likely cost £12-15.
Looking for £100 + post which is a fair bit less than i paid!
[img]
[/img]
Hi, U2U sent for first dibs
Kevin, have dropped you a reply via u2u ......was waiting on someone who'd messaged me to follow up on his initial message, if i don't hear
anything by this evening ( he seemed keen to pick it up tomorrow ) then you're welcome to it - will tell you either way by early evening...
cheers
mark
still available?
sorry, should have popped an update - no, one of the locost members has taken this....
