REMAINDER OF KIT CAR ENGINE / TURBO / SPARES FOR SALE
1. Full turbo set up for most bike engines, this package is ZZR1100 specific:
X2 Garrett TD04’s 2 are spot on, 1 might need a rebuild, intercooler, 316 S/S Turbo plates and ZZR1100 exhaust plate, 316 nominal bore to make home
made manifold, standard ZZR110 down Pipes, plenum chamber and ali plate for carbs / TB’s, naca duct, pipe work, exhaust and exhaust packing, pioto
tube for blow through carbs all £500
2. Full power 24,000Miles ZZR1100 engine + spare engine £200
3. Full box of silicone hoses / braided oil line / ZZR1100 carbs £50
4. Box of spares for the ZZR1100 engines, alternator, sump, x2 starter motors, clutch and basket, fuel pump - various other bits £50
5. Box of random Sierra bits, another oil cooler, steering boots, ZZR1100 clutch slave £25
2/3/4/5 ALL TOGETHER = £275
Paddle shift with two push pull cable-tec - cables £200
Westfield or Caterham windscreen/doors/hood & roll bar £100
GRP Seats (need covers) £40
3 cylinder bias floor mounted pedal box £125
MK Indy prop shaft, Ford axel PCD to standard prop adaptor PCD (fits ZZR1100 adaptor with package) £70
ngine / exhaust rubber bobbins / mounts £15
ZZR1100 oil cooler £25
ZZR1100 prop Adaptor £40
Can deliver free of charge if close.
Can deliver Anywhere in the uk at a cost, price negotiable.
Feel free to call to discuss any bits Antony - 07717843769
Do you know what exhaust housings are on the TD04? If they are HL, I would be interested in buying the one that needs rebuild if you would split?
Hi,I believe 1 is HL and one is HE. Open to offers
Could I have first refusal on the windscreen etc dependent on the width. What is the measurement across the bottom of the screen where it sits on to the scuttle please?
Hi,
I’ve already had someone ask about the screen doors and hood depending on the size. If they are no good to him. They are yours. Thanks
Show me the pedal box pls and some dims
https://www.facebook.com/tee.gray.549/posts/10156536508214624
Are your seats still available and how wide are they
Chris
The seats are 410mm at the widest point at the front of the seats. 390mm at the widest of the arse and 430mm at the widest of the shoulders.
Let me know - chewrs
Thanks for the info
Going to be too wide unfortunately
Chris
Hi, interested in some of the ZZr1100 parts, standard downpipes off the bike? Also the sump and Im after a pair of cams....
Got out like that?
cheers,
For the money - there’s two spare engines!
Why don’t you pop over and have a look?
Will do, when ya in?
Now?
Anytime - tomorrow after work. Up for you
