THese are the lights on my Striker and I want to buy some clear ones to replace the amber but cant match them with anything on offer from cbs. The
lenses are 68 mm diameter....
[img][/img]
[Edited on 3/10/16 by Hammy360]
Wipac. used on late model Hillman Imps. Earlier Imps had a better looking. chrome rimmed Lucas lamp that fits in the same hole.
[Edited on 3/10/16 by britishtrident]
http://wipac-aftermarket.com/acatalog/Classic_Side_Rear_Fog.html
What about these -
http://www.europaspares.com/auto-electrical/lighting/rear-lights/691-lucas-healey-cobra-lights.html
Lucas L760?
None of the above guys :-(
Early land-rover Type?
Shooter
some of the landrover ones might be the same but the vertical sides seem to be covered n a protective sleeve https://goo.gl/images/fkLGpu
i wonder if the manufacturers have slightly changed the profile over the years, certainly they all seem to have the same bigger radius where the
vertical joins the cone end
this is an OEM lucas 760 NEW LUCAS L 760 CLEAR SIGNAL LIGHT LAND ROVER MINI MG RH 551429
Thanks guys,
I'll take one off and see what info I can glean from codes on the lenses
