Hi all asking for my Dad
Is oil dry and cat litter the same stuff
If he use's oil dry can it / will it harm his cat ?
Anyone used it for cat's
Jacko
So let me get this right.... he has an oil spill and want to mop it up with the cat? Should be fine then.
It does really depend how oily your cat is....
Yes - cat litter can be used for soaking up oil spills!
I think Practical Classics? did a comparison of various stuff and cat litter scored best.
It's pretty much the same stuff I think, but why use oil dry for the cat when proper cat litter is cheap anyway.
I use cat litter in the garage to mop up oil spills well enough though.
Think i will send my 90year old Dad to sort you two out
[Edited on 11/12/10 by jacko]
[Edited on 12/12/10 by jacko]
The cat wont use oil dry because, are you ready for this, it doesn't smell right to them so they stay clear. Cat litter is best for oil spills as well as cat spills.
It's called Fullers earth, a well known substance that absorbs most things without changing into something (more) nasty
It's generally the same stuff, however some of the cat litter has anti odour additive... but don't use the pink stuff for the cat; It burns thier feet (slightly).
Cat litter and Oil dry are the exact same thing.....
My employer is the worlds largest producer of Bentonite clay, and we sold our conventional cat litter(non-clumping)market to Oil Dry Corp years
ago.
Conventional cat litter and Oil Dry are both Calcium Bentonite clay that has been calcined.
My employer is the worlds largest producer of Bentonite clay, and we sold our conventional cat litter(non-clumping)market to Oil Dry Corp years ago.
Conventional cat litter and Oil Dry are both CalciumBentonite clay that has been calcined.
Use a clumping litter. Clumping litter is Sodium Bentonite, and developes better strength.When wetted it will disperse in the sand just as if it were
ground to powder.
Better yet...
To do home casting, try contacting a local foundry. often they will give you some of their waste molding sand. This sand has been conditioned and has
bond(clay) added already. It will be sufficient for home use, without trying to blend a workable sand on your own.
[Edited on 12/12/10 by The Shootist]
There are a number of different types of cat litter on the market.
