Frothy diesel at injectors
LoMoss - 16/2/11 at 10:47 AM
Hi
Just changed the fuel filter on the LDV with a duratorq engine after it coughed and sluttered a bit. Got it primed and it ran for a minute or so ie to park up. Now it wont start and I cant get any pressure at the injectors, just frothy diesel. I am not convinced the filter is a good fit.
Any thoughts please.
Does this pump have any issues?
Thanks in advance
Moss
martin1973 - 16/2/11 at 10:57 AM
air getting in somewhere
did it knock when u started it
LoMoss - 16/2/11 at 11:09 AM
Done a bit more investigation and the primers not drawing up fuel. It also does not seem to have much pressure.
[Edited on 16/2/11 by LoMoss]
ashg - 16/2/11 at 11:57 AM
sounds to me like there is still air in the pump. crack the pipes on the injectors stick some rags around them and crank it over. nip the injectors back up and try to start it again. has never failed me yet.
LoMoss - 16/2/11 at 12:06 PM
The pump is not giving any pressure it should spray all over the place when I do that.
Mr Whippy - 16/2/11 at 12:30 PM
is there a bleed valve on the pump too though?
daviep - 16/2/11 at 01:28 PM
There is a small yellow plastic bleed valve on the filter head, open this and use the hand pump until the filter is full, don't be afraid to spill some to make sure the filter is properly full, then open all the injectors or at least or as many as possible and crank until you get diesel at the injector.
What makes you think the filter isn't fitted correctly? It does only fit one way and they normally feel quite positive when they go fully home, if it's not right you won't manage to turn the locking collar fully.
The duratorq has well known issuses with the injection pump and a new pump is about £700
Davie
coyoteboy - 16/2/11 at 01:34 PM
Pinhole in the primer? This wouldn't necessarily leak, but would draw air in before the pump, allowing it to be turned to froth?
(No idea about the engine, just working through the thought processes).
[Edited on 16/2/11 by coyoteboy]
LoMoss - 16/2/11 at 02:26 PM
The last time I changed a filter, fuel sprayed everywhere under pressure from the loosened injectors. Not getting that this time.
After some internet surfing some hints are....
1. have at least 1/2 tank of fuel
2. Fill filter twice, ie let it settle then top up
3. suck fuel through filter and pump
4. bump start
5. they are notoriously difficult to prime.
Davie: £700 its more than the vans worth. Had running problems and changed filter, got it primed and it ran for 5 mins. So either more air into pump or pump knackered!
Coyote: Had the primer to pieces and can find a fault there
mad-butcher - 16/2/11 at 03:31 PM
I assume you smeared the O ring with diesel when you fitted new filter. My bannana transit was the same after a filter change, used to have to tow it to get it started but after initial start never missed a beat
tony
LoMoss - 16/2/11 at 04:15 PM
Its running now. Topped tank up with 35ltrs and pumped the primer like a mad thing. Run around the block and it seems ok
