snippy
posted on 7/1/11 at 04:29 PM |
For info a standard 2.0 Zetec flywheel will definately fit inside a standard type 9 bellhousing. That`s what`s in my car!
omega0684
posted on 7/1/11 at 04:43 PM |
i wouln't pay more than £5 max!
RichardK
posted on 7/1/11 at 05:05 PM |
ditto, thats what in mine too.
Rich
Gallery updated 11/01/2011
steve m
posted on 7/1/11 at 06:18 PM |
Does the engine bolt ok to that bellhousing?
(as it did appear to when i saw it)
and does the flywheel bolt to the engine ?
If so, it can only be a wrong flywheel
snapper
posted on 7/1/11 at 06:21 PM |
You deffo have a modified RS2000 bellhousing but don't need to replace it, the bolt pattern and internal size is the same as any type 9 steel
bellhousing.
Your problem is all about the flywheel, get the right one and the problem is solved
scutter
posted on 7/1/11 at 06:28 PM |
Your 2.0L flywheel will fit in a RS2000 alloy bellhousing, trust me mine runs fine
You need to make merry with the angle grinder! Arrowed below is the area that currently isn't round in the one you have. Dress this out and it
will fit. I've attached a pic of what it should look like post fettling.
5 min of work and you'll save your self cash and about 5Kgs as the replacement steel one weighs a ton.
ATB Dan.
[Edited on 7/1/11 by scutter]
pekwah1
posted on 7/1/11 at 07:13 PM |
nice one, i was kinda swaying towards just angle grinding it originally but didn't want to jump straight in in case i'd be doing something
wrong...
If the general consensus is that this is ok to do, then grinding it is!
Oddified
posted on 7/1/11 at 07:19 PM |
If your having to take a bit out of the bell housing for the flywheel, surely the starter motor-ring gear engagment is going to be an issue. What
starter motor do you use for this setup?.
Ian
pekwah1
posted on 7/1/11 at 07:41 PM |
yeh that's the only other issue i guess.
I only have one starter at the moment, but it actually fouls on the sump of the engine anyway, so that won't work....
i've been told that a pinto starter should be ok....
Oddified
posted on 7/1/11 at 08:32 PM |
I don't know for sure, but don't be to surprised if it doesn't fit.
The reason i was asking is i had a similar problem with my set up, nasp cosworth with ally flywheel (cosworth size) to a type 9 box (tranx gear kit).
The flywheel justed fitted into the cast iron bell housing, but on upgrading to a magnesium one i also had to shave the inside out for clearance. As
for the starter, a pinto one doesn't line up, the cosworth flywheel is larger than a pinto. For several years i did use a pinto starter ( lucas
M79 type) though which i'd modified by slotting the bolt holes/machined flange to adjust the starter further out (6mm) and fitting a 9 tooth
gear. On rebuilding the engine i upped the compression to 12-1 and the old starter became marginal at best, the M79 is only a 0.9Kw motor. So
i've now got a Bosch starter from an escort/orion diesel (£25 on ebay) which is 1.7Kw and a geared output, to make it fit i machined off the
mounting flange and pressed/locked a home made one on putting the starter where it needs to be. Works perfectly and it shows the engine who's
boss
There maybe a starter out there that's right to start with but i couldn't find one.
Ian
sm1ggles
posted on 7/1/11 at 09:48 PM |
starter mtr
i have a 1.8 zetec fitted to a type 9 using a 1.8 zetec flywheel adapted for the pinto clutch and my starter is one from a 1.8 cvh sierra the pinto
starter does fit but you need to space it out from the bell housing by about 6mm
pekwah1
posted on 7/1/11 at 09:49 PM |
ok the starter i have appears to be a capri pinto one.
it's the same as in this pic:
http://www.classiccarsforsale.co.uk/dbimages/0920834001285763250
I've just removed the bellhousing so i think i might go and have a look at another one and compare...
[Edited on 7/1/11 by pekwah1]
Oddified
posted on 7/1/11 at 10:07 PM |
I think it all depends on just which bits your putting with what, some combinations of flywheels, bell housing and starters work and others
don't.
Logic says that if your now putting a different flywheel into the old bell housing and it doesn't fit without shaving some out...it's
obviously bigger than the old one that was in there, hence the old starter if correct before is now probably not going to be
Ian
procomp
posted on 7/1/11 at 10:55 PM |
Hi
An RS2000 Ali bell housing with a std 1800 flywheel with a DOHC Sierra/ Granada starter will all fit together with no problem what so ever. That is
exactly what has been run on many 750Mc and wetfield race cars have run where the 1800 zetec with std fitment flywheels is compulsory.
It sounds like you are already aware of what clutch cover and drive plate with thrust bearing and extensions are needed.
cheers Matt
Edit. The only problems you may encounter with starter motors is with them catching the side of the sump depending upon which sump and make of starter
you are using. If memory serves me right it's the Bosh unit that is of a smaller design and fits better. Also the DOHC unit does not need
spacing from the mounting face.
[Edited on 7/1/11 by procomp]
pekwah1
posted on 7/1/11 at 11:08 PM |
exactly, that's what i had read which is why i'm not quite sure why mine isn't fitting properly....
i think i'll just have more of a play and see what happens
scutter
posted on 7/1/11 at 11:11 PM |
All the flywheels have the same external diameter, check out halfway down this
Link for another opinion and some
pic's
Atb Dan.
procomp
posted on 7/1/11 at 11:23 PM |
Hi
Thinking about it the 1600 if that's what it is maybe bigger to give a smother running engine. Although i would of thought it would be just
heavier rather than bigger in diameter as such i have never had a 1600 one to hand though. And i do know that there are a few very strange flywheels
available for the zetecs as the one that Westfield used to fit in the early days of them fitting the zetec as std fitment was a very very heavy item
that i have never managed to track down as to what it was supposed to be fitted to as std by ford. If i still have one lying around ill check the part
number but to honest given it's weight i think it was thrown away and made a scrap man very rich.
A genuine 1800 item is what is required as that is guaranteed to be a fit assuming that the alloy bellhousing in question has not been altered to much
where that casting has been removed and re welded up.
Cheers Matt
Edit. The above post would make the suggestion of a larger Dia 1600 item a no no.
lotusmadandy
posted on 8/1/11 at 09:59 AM |
I guess i must have been given some mis-information regarding the
2.0 flywheel then.I was under the impression that it didnt physicaly fit due to the extra thickness
around the edge fouling the housing.
I have never actually tried to fit one,still you live and learn......
pekwah1
posted on 8/1/11 at 11:34 AM |
thanks again for all the help guys, i'm going to try and have a go with it over the weekend again and see if i can get anywhere with what
i've got, i'll let you know!
pekwah1
posted on 15/1/11 at 03:43 PM |
well as there's a fair amount of responses, thought i'd give you all an update.
You may have seen my other thread where i managed to empty the entire contents of my engine oil all over my clutch flywheel and then onto my garage
floor which delayed me a bit, but i've finally got the engine mated to the gearbox!
Still a bit unsure of exactly what flywheel i have, but i ground off two lips from the bellhousing which petruded slightly inwards, and i've
just been outside tinkering and the engine with clutch assembly slipped straight onto the gearbox no problems at all!
To top it off, met a fabricator the other day (who was restoring a mk1 escort and putting a zetec in) who welded up my engine mounts, and would you
believe they fit first go!! turns out i can use a tape measure after all!! he wasn't happy about me using galvanised steel though.....
Thanks a lot for all you help again!
