craig1410
posted on 22/4/14 at 11:46 PM |
quote: Originally posted by wylliezx9r
My wife had similar symptoms to what you describe for about the last 10 years. Went to the doctors etc etc but nothing was found. I read a book called
grain brain which describes the problems gluten can have on the body including migraines amongst lots of other things. I told her to give it up gluten
and see what happens, Within a couple of days the migraines stopped and have never come back.
[Edited on 22/4/14 by wylliezx9r]
Another vote for Grain Brain - that book will make you think twice about listening to "the establishment" when it comes to healthy eating.
I managed to virtually eliminate Asthma which I've had since the age of 12 (now 41) simply by avoiding Gluten and Sulphites from my diet. My
whole family now avoid Gluten as much as possible and are enjoying improved health. Note that it takes up to 30 days to see the full benefits of
gluten avoidance and it is extremely difficult to avoid as it is in almost everything including cooking sauces. Read the labels of anything you
eat.
Good luck, I hope you find a solution.
C.
posted on 23/4/14 at 05:53 AM |
One of the symptoms of carbon monoxide poisoning is headaches. Carbon monoxide is always a major suspect when investigating sick building syndrome.
Re lead, lead like other heavy metals it lingers in the body for a very long time, the change in environment when going on holiday is not going to be
long enough to change the symptoms.
[Edited on 23/4/14 by britishtrident]
ali f27
posted on 23/4/14 at 07:18 AM |
Bit of along story but here go,s i suffred form indigestion all my life untill meeting jane who is gluten intolerent i am 59 and was crippled with
joint pain struggling to get my work done box of rennies daily anyhow when we started living together we started eating same diet just made life easy
within a month joints where beginning to improve and a year later i am brand new would never have belived it if some one had told me dont rule it out
claire not hard to be gluten free we eat really well good luck
whitestu
posted on 23/4/14 at 07:20 AM |
Where we are the water company will replace any lead pipework leading to the property if you replace yours up to the boundary. Might be the same where
you live.
Like other have said though, lead pipe oxidises meaning the lead shouldn't contaminate the water.
mcerd1
posted on 23/4/14 at 08:36 AM |
lots of people have a mild gluten intolerance with various symptoms (my GF's mum just gets an upset stomach)
but there are so many possible causes the only way to isolate the real cause is to try one thing at a time...
getting the water checked and checking the CO levels around the house have got to be the first things - they are easy to test for and the most serious
for your health
you live.
we've got something like that up here
but ~10 years after it was all redone in plastic we found a leak in the 10m section of lead pipe they'd missed / hadn't bothered to
replace
[Edited on 23/4/2014 by mcerd1]
MP3C
posted on 23/4/14 at 09:05 AM |
+1 for carbon monoxide. dad had the similar symptoms a while ago, really bad headaches and he seemed tired all the time. we tested everything and
eventually it was found to be carbon monoxide from the gas fire. Once fixed he was fine.
Matt
me!
posted on 23/4/14 at 10:51 AM |
You could switch to wine?
mcerd1
posted on 23/4/14 at 11:27 AM |
^^If I remember right cider would be better
Phil.J
posted on 23/4/14 at 02:56 PM |
I suffered from migraines for years, regularly taking soluble paracetamol about 5 times each day. When I had kidney problems I stopped the paracetamol
and was prepared to live with the migraines, but within a few days the migraines stopped. I had been suffering from paracetamol poisoning which can
cause violent headaches and migraine!
motorcycle_mayhem
posted on 23/4/14 at 03:13 PM |
I'd be very suprised if lead in the water supply was linked to the problems you're experiencing.
The bioavailability of lead is quite low, as has been pointed out. Pipes will form a protective scale on the inside, it's probably only your
main-to-house that remains lead, simply running the tap for a few minutes should clear any absorbed lead in that section.
Your comment as regards lead in petrol.... quite interesting. Thing is, again, the bioavailability of lead particles neatly baked into exhaust
particulates is extremely low. Unless you were into eating nothing but the grass along the M25 during the leaded period (yes, I was part of the
research effort at the University of Surrey), I doubt if dietary lead is an issue. However, stop eating tinned salmon/tuna if heavy metals worry you.
BTW, petrol (sans lead) is now even less healthy, more aromatics, more heavy ethers, all very toxic. That octane level has to be maintained
somehow.
How is your home heated? If it's a modern sealed box, amongst other sealed boxes (all venting CO), then have a good look at CO.
Any formaldehyde/ureas/etc. (furniture/fittings/insulants) can cause some issues with some people.
Any high voltage lines around, or a big microwave emitter?
craig1410
posted on 23/4/14 at 04:00 PM |
The other thing to consider is that the absence of headaches when away from home might not be so much to do with the change of environment but might
be more to do with the change of scene possibly reducing stress. For example, when we are at home we tend to be in a work, eat, rest cycle whereas
when on holiday or away from home that cycle will usually not include work any more.
So, if general stress could be the cause then try to make time to relax through a combination of exercise (eg. simply walking), breathing, meditation,
yoga, pilates etc. Whatever you can fit in to your life.
Also consider if your bed is causing back or neck pain/stiffness to trigger the headaches (very common) and make changes to see if you can remove the
trigger. eg. Try sleeping on the floor with a mat or old duvet underneath you. I'm not saying that will be particularly comfortable but it might
give some clues as to the cause. This is also something that will be different when you are away from home.
I hope you find the solution.
woodster
posted on 23/4/14 at 06:28 PM |
I don't know much about lead pipe work but I do know that plumbers who worked with lead were given a bottle of milk a day to drink and protect
themselves .... My old Dad told me that
posted on 23/4/14 at 07:05 PM |
I get migranes except when I'm on holiday. The answer is stress. I doubt lead ismy issue. For what its worth I replaced my lead piping with
plastic. Shed loads of stress- made it worse
clairetoo
posted on 1/5/14 at 10:26 PM |
I got the results from the water test today........
They phoned before turning up , and said dont run the water - bad news was I had flushed the toilet a few minutes before , so the water had only sat
in the pipes for an hour or so before being checked .
And the test result - 9.1 micrograms per litre , when the current drinking water standard is 10............
So maybe 17 years of filling the kettle first thing in the morning , and often first thing when entering the house may have something to do with my
problems.........
Its cuz I is blond , innit
Claire xx
Will weld for food......
ali f27
posted on 1/5/14 at 10:31 PM |
hope youve got to the bottom of it
posted on 2/5/14 at 06:39 PM |
The acceptable level of lead in the water supply used to be 25 micrograms per litre prior to 25/12/13 and was reduced to 10 micrograms after that
date. If you only have 9.1, that would suggest you are well within the parameters wouldn't it? So may not be the source of your
problems?.......
Phil
