<<  1    2    3  >>
New Topic New Reply
Author: Subject: is this worth the money ???
wacomuk
posted on 27/5/05 at 10:26 AM Reply With Quote
right got new lump in and its running! used 2 sump gaskets to clear the crank after afew miles the crank oil seal started to leak so new one of them went in all is good un till (10 miles later @ about 20mph) the cam belt tensioner decided to die the belt came off, all the valves are bent so im about £400 out of pocket and i still cant drive im westy CACK!!!!!!!!
[Edited on 27/5/05 by wacomuk]
ned
posted on 27/5/05 at 10:30 AM Reply With Quote
was it a late engine with the plastic tensioners?
sorry to hear of your misfortune, maybe next time you'll put a cambelt kit on it??!
you just never know with second hand high milage units out of hot hatches or off ebay
best of luck again..
Ned.
beware, I've got yellow skin
wacomuk
posted on 27/5/05 at 10:34 AM Reply With Quote
the engine was out of a 93 cav with a cat
you live and learn cam belt kit is a must from now on !!!
ned
posted on 27/5/05 at 10:53 AM Reply With Quote
do you still have the head from the other engine? was that all intact (valves etc), can it be a straight swap? head bolts/gaskets only come to about £50..
Ned.
wacomuk
posted on 27/5/05 at 08:15 PM Reply With Quote
Ned.
yes the head from the other engine is ok and im concidering swapping it over, i need a head gasket kit / head bolts / cam belt KIT!!!!! and the head skimmed i could prob get it all dun for around £100
wacomuk
posted on 5/6/05 at 09:35 PM Reply With Quote
all parts have been bought! the head will go off for skimmimg this week
Jeffers_S13
posted on 6/6/05 at 09:53 AM Reply With Quote
Are you registered on the SXOC ? think I recognise your boardname.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 9/6/05 at 05:06 PM Reply With Quote
good luck mate- the bad luck has to run out soon i've been involved in a few xe nightmares myself but they're good engines! although not as good as a bike engine.................
wacomuk
posted on 10/6/05 at 03:15 PM Reply With Quote
yes mate !! im mostly in the s12 section as iv got a nissan silvia turbo
this be it
http://img.photobucket.com/albums/v296/wacomuk/DSC00044.jpg
[Edited on 10/6/05 by wacomuk]
wacomuk
posted on 10/6/05 at 03:16 PM Reply With Quote
hears hoping
wacomuk
posted on 10/6/05 at 11:13 PM Reply With Quote
looks like the westy back on the road this weekend !
wacomuk
posted on 14/6/05 at 09:47 PM Reply With Quote
the westy is back !!!!
<<  1    2    3  >>
New Topic New Reply
