posted on 17/1/09 at 05:39 PM |
MIG: sticking spool on spindle ? copper slip
Anyone got any genius ideas for how to stop the wire spool sticking on the spindle?? Even with the spool clamp slackened right off it sticks like
crazy (it's pretty difficult to turn even by hand when it jams!!).
Would copper slip be a good option? I'm not sure how plastic friendly it is... Otherwise I might try sanding the spindle a bit with some fine
emery paper to smooth it a bit- there are quite a few scores on it....
My welder has moments of working amazingly but then the spindle jams and it all goes horribly wrong....
Is this a common problem with hobby machines?
big_wasa
posted on 17/1/09 at 05:46 PM |
Yeh ive had that with my old sip machine.
I think i used to bore the reel of wire out and put a spot of grease on the spindle.
The wire feed on these machines are so poor that the smallest amount of sticktion stalls them.
jacko
posted on 17/1/09 at 05:47 PM |
Do you have a photo of the spool and shaft ?
all the welders i know of have a tube that spins on the shaft that has a spring at the end to adjust the tension and the spool goes on the tube
[Edited on 17/1/09 by jacko]
posted on 17/1/09 at 06:07 PM |
The word SIP was the first that came into my mid too
Tends to be a problem that gets worse as the reel nears its end.
Might also be an idea to check the liner and spring on the feed roller
posted on 17/1/09 at 06:36 PM |
The liner is pretty new and the feed roller is working fine. You can see the wire between the spool and the wire feed suddenly go really tight when it
jams...
It's a Clarke 90 MIG. It's supposed to be that the inner bit of the spool rotates on the plastic spindle. I suspect it's just pants
design and needs a bit of TLC to make it work better.... A bit of fettling and copper slip it is!!!
oliwb
posted on 17/1/09 at 08:55 PM |
Just a problem with Hobby welders TBH. My older Draper one did it a lot. I did as you suggested and sanded the spindle down a bit and think I use
silicone grease rather than copper as it works with plastic better. Have since got an Arcos Lincoln MIG and a TIG too and the difference from
Hobby/Semi-pro to Pro is amazing...produces really good welds. But obvoiously the cost is not ideal for the average hobby-ist!
Oli.
owelly
posted on 17/1/09 at 09:37 PM |
Further to what the others have said....
don't use copper grease. If it gets where it's not wanted, it can give you all sorts of bother. Like my chum who put it on his battery
terminals. The grease got warm, trickled across to the battery clamp and caught fire.
http://www.ppcmag.co.uk
zilspeed
posted on 19/1/09 at 06:35 PM |
Does it happen with the BFO 15kg spools too
Like on my 50 quid Clarke 160 ?
![](/galpreviews/a872335-Small IM000613.jpg) ![Rescued attachment Small IM000613.jpg](/gallery/a872335-Small IM000613.jpg) Rescued attachment Small IM000613.jpg
posted on 21/1/09 at 11:02 AM |
Ordinary LM grease would work better than Copaslip. You need a lubricant not an anti seize compound. Copaslip dries up, grease doesn't.
