Echidna
posted on 17/1/09 at 05:39 PM |
Echidna pedalset
They are available on ebay.co.uk
Please send me an email at theodragonas@gmail.com if interested. Thanks!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=220343852822
kitCARBON is the new carbon composite parts company specialising in kitcar parts. We can make parts to order in carbon, carbon/kevlar, kevlar,
texalium and more!
For any question, just U2U or email me at
Echidna
posted on 17/1/09 at 05:55 PM |
Please note that they can be made with an adjustable pedal pad and with adjustable pedal ratio at an small extra cost.
![](/galpreviews/a871211-pedalpad.jpg) ![Rescued attachment pedalpad.jpg](/gallery/a871211-pedalpad.jpg) Rescued attachment pedalpad.jpg
texalium and more!
Echidna
posted on 17/1/09 at 05:56 PM |
adjustable pedal
![](/galpreviews/a871212-new.jpg) ![Rescued attachment new.jpg](/gallery/a871212-new.jpg) Rescued attachment new.jpg
texalium and more!
oliwb
posted on 17/1/09 at 09:01 PM |
Seem a good price. You do know that the FEA you've done is a bit irrelevant as the restraints have not been setup correctly? You've set
it up to show a force acting down on the pedal (which is correct) and then set a restraint for the bolt through holes at the bottom of the pedal. You
should have set this as a felxible or connector and then set the mounting hole for the bias bar/master cylinder push rod as another force exerting to
counteract the force on the top of the pedal. I think you'll find that your new design is probably weaker if you refine the FEA. I'm
sure its still well over-engineered though. Oli.
Echidna
posted on 18/1/09 at 02:27 PM |
Oli, you are right on this. The reason i made it simpler was because i didn't want to find the actual limits of the pedals but only make some
simple comparisons between several designs. If the original design is strong enough (and many people have tested it in practice), my new design will
be even stronger, while being lighter.
texalium and more!
