posted on 29/9/09 at 03:54 PM |
Auto Welding Helmet?
Well, sitting here with my face stinging and a touch of arc eye I think its time for an auto helmet...
Is
THIS one any good.
Any recommendations?
graememk
posted on 29/9/09 at 03:56 PM |
spend a bit more money on one mate....
t16turbotone
posted on 29/9/09 at 03:58 PM |
looks good to me, mines very similar but cost me 89 quid!!
am i correct in thinking your fitting a T series in your 7 ?
blakep82
posted on 29/9/09 at 04:00 PM |
i've never really trusted them, in case they decide to fail one day... therefore, don't buy cheap
________________________
posted on 29/9/09 at 04:01 PM |
That one looks very much like the one I've got and it's great.
Depends on what you're going to use it for though. MIG gives off a fair bit of light, TIG helmets need to be more sensitive IIRC.
posted on 29/9/09 at 04:08 PM |
T16 may be going into my Jago.. we'll see.
Need for a mig to fab a new chassis for the jeep.
Just seen a 'better' one from the same seller but has specs and adjustments..
chrsgrain
posted on 29/9/09 at 04:09 PM |
The one I've got blocks all UV, so even if it fails (which it never has) you don't get arc eye, just a white spot in front of your eye for
a few seconds (I have 'tried' it by not switching it on first, and its just a bit bright really....)
I would take advice from someone who knows, maybe MigTigArc in Portsmouth or Weldequip on the migwelding site...
Your eyes are important!
Chris
Mr G
posted on 29/9/09 at 04:10 PM |
A guy (weldequipe) over on the mig-welding forum sells decent masks at a decent price
http://www.mig-welding.co.uk/forum/
[Edited on 29/9/09 by Mr G]
flibble
posted on 29/9/09 at 04:13 PM |
looks very similar to the one I ordered from the USA last year for a similar price, not great quality but have never tried a more expensive one to see
the difference.
It goes dark instantly which is pretty much all I could ask of it
Also, about the trusting them incase they fail - my screens is a fairly dark green as standard so wouldnt blind you instantly if it failed to notice
you arc up ![](/images//smilies/smile.gif)
flak monkey
posted on 29/9/09 at 04:15 PM |
I bought a cheap one, and other than the hinges going its still on its first set of batteries, is fail safe and solar powered too.
Been pretty good with moderate use over the last couple of years.
Sera
http://www.motosera.com
blakep82
posted on 29/9/09 at 04:17 PM |
hmm, if they're UV blocking anyway, i might consider one myself. would certainly make things easier in a cramped space. nothing worse than the
torch moving when you flip the visor down, stiking an arc to find you're about 1/2" out
Paul (Notts)
posted on 29/9/09 at 04:26 PM |
Try these...
http://www.diywelding.co.uk/products.asp?d=2&c=1
had the cheep parweld one for a year and seems very good.
[Edited on 29/9/09 by Paul (Notts)]
ashg
posted on 29/9/09 at 04:30 PM |
i got one of those cheepp ones but it went funny after about 6months. it still works but depending what angle you look through the screen depends on
how dark it is. i gave up in the end and got a proper £200 esab one. in a word its the muts
if i didnt have £200 and had to buy one it would be a parweld one cost around 40-60 ish
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 29/9/09 at 05:13 PM |
If they fail they go dark. You can't get flashed as they are shade 4 or 5 in the light state and even clear UV resistant shades will stop arc
eye. I got one same as that free with my new welder and it is fine for anything I do.
robocog
posted on 29/9/09 at 05:37 PM |
Also got one of the really cheap ones on eBay after getting it wrong one day with my old flip down job and suffering real badly with arc eye...I swore
it would never happen again for the sake of the £20 or whatever it was to buy the auto darkening one
Mine has been just fine and dandy, doesn't eat batteries (still on original ones 12 months on) or have any bad habits
I have done a bit of welding since and no arc eye yet and can see well enough when it "goes clear" to not be forced to to flip it up to
see what is going on ..I guess thats the whole point of them :-)
When it stops working (I suspect through abuse rather than electronic breakdown) I would buy the same make/model again
Regards
Rob
Dangle_kt
posted on 29/9/09 at 05:41 PM |
Ive got one very similar but from the states, works a treat but the headband is a bit rubbish - it broke at the adjuster so its now held tight with a
bit of gaffer tape.
Still works a treat, but its no top line helmet.
40inches
posted on 29/9/09 at 05:48 PM |
Good quality helmets from here http://www.autodarkhelmet.co.uk/ I have the SX and it's superb, had a cheap ebay one before, I didn't
realise how bad it was until I got this one.
As said above, clear safety glasses will stop arc eye.
plentywahalla
posted on 29/9/09 at 06:41 PM |
Suspiciously cheap IMHO. Best pay more for an adjustable one. (9-gas, 11-mig, 13-Tig) using the wrong shade can cause the shield to temporarily quit.
Also need adjustable sensitivity for different light conditions. In bright sunlight welding shiny metal the mask will sometimes not react properly.
I struggled with a cheap mark until I realised I was learning the hard way
DavidW
posted on 29/9/09 at 07:01 PM |
quote: Originally posted by Paul (Notts)
Try these...
Me too. Works well.
I got mine from eBay for about £40 delivered.
oliwb
posted on 29/9/09 at 07:29 PM |
I bought a Miller auto helmet. Its amazing. I had a cheap one before and it was totally naff....especially with TIG welding. The miller has 4
sensors so even if your hand ends up between the arc and one of the sensors it will still darken. I would save up and get a more expensive one (think
mine was about £140) the measurable difference is easily 5 times that of the cheaper £30 one I had before.
As has been said before they filter UV whether the helmet is on/dark or not. So although its bright and you wot see much for a min or two theres no
lasting damage and no chance of arc eye.
Oli.
twybrow
posted on 29/9/09 at 07:41 PM |
I got one of those cheap ebay ones, and it has been the best £28 I have spent on tools in a long while - it considerably improved my welding (MIG). It
is adjustable for sensitivity and to how dark it goes, plus it came with a load of spare lenses. The battery is still the original, and safety wise it
is dark when switched off, so fails safe. Go for it - for less than £30 it has to be worth a punt!
Wadders
posted on 29/9/09 at 07:50 PM |
Do a search for ESAB origo tech, i bought one from my local welding supplier in leeds (pennine welding) for £55+vat
Great value for money considering the name on it.
I use it for both mig and tig.
Al.
speedyxjs
posted on 29/9/09 at 08:22 PM |
Mine cost £17 on fleabay 2 years ago. Still works fine and on same set of batteries.
The batteries tend to power the lighting rather than the darkening so you wont have any probs with arceye.
tomblyth
posted on 29/9/09 at 08:36 PM |
I use one of these! and it goes down to 5 (for alloy) and its mint (dear though!)
optrel
Mansfield
posted on 29/9/09 at 09:01 PM |
Go for the Parweld, I wanted a dearer one but DIYWELDING (Central Welding) talked me out of it. More than twice as good as the cheaper ones at less
than twice the price. I also have a cheaper one. Will TIG down to small amps if that is your thing, as well as all the normal MIG stuff.
£39.99 delivered, you wont look back.
Parweld
[Edited on 29/9/09 by Mansfield]
