l0rd
posted on 2/11/10 at 09:10 PM |
WTD: Stainless Steel exhaust offcuts and parts
In order to create the tintop exhaust on my previous post i am after some offcuts if you have any before i go on ebay or I need ideas of where i can
find these as cheap as possible.
Cash waiting.
Stainless steel parts:
2 x 15cm 3"OD straight through pipe
80cm of 1"3/4 OD straight through pipe
Y piece collector 2-1 inlet 1"3/4 OD outlet 2" OD
2 X Flat bar 30mm X 2mm X 500mm
2 X Square plates 100mm X 100mm X 2mm
snapper
posted on 2/11/10 at 09:15 PM |
Agricultural dairy pipes
I eat to survive
I drink to forget
ahunt
posted on 2/11/10 at 09:19 PM |
Hey,
I can get the 2mm flats for you if you like? I have to go to the steel store tomorrow so ill pick them up if you want?
Adam
l0rd
posted on 2/11/10 at 09:25 PM |
quote: Originally posted by ahunt
Hey,
Adam
Thank you very much for the offer. Let's see if anyone else has some that want to get rid off and i will u2u you later to tell you.
ahunt
posted on 2/11/10 at 09:28 PM |
Ok no problem itll only be pennys and to post
hughpinder
posted on 3/11/10 at 09:15 AM |
I can let you have 63.5 od *1.5 thick stainless pipe, but its 316 grade.
Regards
Hugh
l0rd
posted on 3/11/10 at 10:17 AM |
Regards
Hugh
Thank you for the offer.
I will keep you in mind. I have just found one company that they can supply everything. I need to ring them to see if they can only provide the
lengths that i need.
I was thinking that instead of a Y piece 2-1 collector to use some 63mm pipe and then make it oval to fit 2 38mm ones. The maths do add up fingers
crossed.
