ned
posted on 7/7/11 at 02:42 PM |
Locost 7 unfinished project
For sale is my unfinished project which has sat in my garage the last few years. I've finally decided I'm unlikely to ever finish it, so
it's time to let it go. This has cost me over 10k over the years to get to it's current state. I'd estimate you could get it up and
running and tested for around £1000-1500. Yes I’ve deliberated hard and no I don’t have the time or inclination to do it myself anymore. It was
originally intended as a track orientated but road worthy car. It could also make a good trackday car if you didn't want to test and road
register it.
Car spec is:
Powder coated home built locost book based chassis with additional triangulation as per some of the aussie mods, rollbar with backstays, fully
welded
Sierra track suspension: GTS dedion rear end, mnr rosejointed front wishbones with turnbuckle top adjusters
Ally sides and rear panel (still with protective film on), red grp scuttle, bonnet, nose, black wings front and rear
fibreglass r500 style seats, not padded or upholstered but mounted on adjustable runners
carbon faced fibreglass dash backed with ply for rigidity
bias adjustable pedal box
hydraulic clutch with concentric slave cylinder, ally adapter bellhousing
type9 box, professionally made propshaft with sierra dif and shafts
led rear lights, bike style front indicators
racetech gauges with SPA tacho with inset digital speedo and shiftlights
polo radiator with samco hosing and ally joiners
vauxhall xe engine built up from stripped, rebored and dipped block:
88mm oversize high compression pistons with thicker laminated headgaket to reduce compression slightly
steel rods, reground crank, balanced with lightweight steel flywheel and twin plate sintered clutch
steel oil pump gear, remote filter with take off plate, shallow westfield wet sump and pickup
head rebuilt with double valve springs and uprated cam, vernier pulleys fitted and timed
direct to head throttle bodies with dta ecu, higher flow rate bosch injectors fitted, fully mapped on rolling road with printout 220bhp, 169lbft
small daihatsu type alternator fitted and working
custom wiring loom built with complete wiring diagram plus all ecu loom and sensors of course
redtop gel battery
baffled ally fuel tank with swirl pot and dual pumps (low pressure from tank to pot and high pressure to fuel rail) both with filters, braided hoses
and fittings, pressure regualtor and return lines etc.
larger hispec ally 4 pot from calipers, sierra rear disks
cortina front uprights
escort rack with ally clamps and track rod extenders, sierra column and boss with small mountey steering wheel
simpsons custom 4-2-1 matched length stainless exhaust with largest silencer that would fit inc lambda boss.
caterham minilight wheels with yoko a539 tyres
bad bits:
engine has not run up for 2-3 years and believe it had developed a sticky oil pressure relief valve which would need checking prior to running engine
up again
battery condition will have deteriorated, might be usable again if plugged in to an optimate or just fit a new battery
there is no headertank, it was removed and put on a friends car which was subsequently sold
there is a full tank of old superplus fuel in the tank that'd probably need draining and replacing or mix with superplus to get the octane up
and stick it in your tintop!
jobs to get it roadworthy for test when last worked on:
trims and edging all over for sva/esva/iva whatever it's now called
speedo/magnets on propshaft needed sorting/configuring
front indicators need extensions and possibly height altering
one front wing sill needs fitting
needs a grill
engine map might need altering for emissions, this wasn't considered when it was mapped
You could get it up and running very cheaply as a track car or for a little more work to test it, it would make a very fast road car.
I’m looking for £3200ono and am in no real rush to sell but interested parties can contact me and come and view and I would consider sensible offers.
It’d be worth more in parts but I don’t really want to break it. Located in Guildford, GU2.
I have other parts, spares, documents, knowledge etc that will be passed on to the future owner.
[Edited on 7/7/11 by ned]
beware, I've got yellow skin
SALAD
posted on 7/7/11 at 02:57 PM |
Ned NOOOOOO!!
Get it finished, I was looking forward to seeing yours go! Worth reconsidering surely?
If not, my neighbour may be interested.
eddie99
posted on 7/7/11 at 03:03 PM |
Wow thats cheap, i would split it and sell it if i was you....
TimC
posted on 7/7/11 at 03:05 PM |
Bargain-o-rama.
ned
posted on 7/7/11 at 03:10 PM |
Well if you think it's too cheap what should I be asking for it? It's only ever worth what someone is prepared to pay for it! It's a
lot of parts but huge hassle to split it and mostly just labour to get it going, then the task of getting it iva'd.
I was basing my price on a road registered car minus the cost I estimate it'd take to get it on the road. Yes it's a good spec but
it'll only ever be a locost, it'll never demand the residual of a westifeld or caterham. If it takes me a couple of months and £1500 to
get it road registered and sell it, I won't make a lot more money and it'll take time and hassle so selling as is isn't going to
lose me much money over finishing it, if I had the inclicnation to do so?
TimC
posted on 7/7/11 at 03:13 PM |
I think you've pitched it right to be honest but for that spec of car, assuming it's well put together you should sell at very close to
your asking price. You might sell it at £4k but you might wait 12months to do so.
big_wasa
posted on 7/7/11 at 03:26 PM |
For what its worth Ned I think your on the money with out breaking it. Breaking the engine / box / bods and ecu seperate may well do better for you.
There isnt a great deal of money about and those that have want a bargain.
A locost no matter how well made will allways make less than an mk.
I see the value of mine as around £3k
SALAD
posted on 7/7/11 at 03:35 PM |
I reckon about 6K when registered with that spec regardless of being 'only' a Locost. So 4K is more like it......in my opinion.
Finish it Ned!
ned
posted on 7/7/11 at 03:39 PM |
Feel free to buy it and make yourself some money Mr Salad
I'll try and find some up to date photos and remember what spares will be bundled in with it later to give more information to potential
buyers..
SALAD
posted on 7/7/11 at 03:47 PM |
I will let you know if my neighbour is interested.
bob
posted on 20/7/11 at 09:43 AM |
Any interest Andy ?
lotos
posted on 22/7/11 at 07:56 AM |
u2u sent
ned
posted on 22/7/11 at 11:34 PM |
Had a couple of potentially interested people get in touch but the weather hasn't let me clear the garage to get any recent photos. That said
some of the older ones show more or less the state it was at when I stopped working on it:
http://www.locostbuilders.co.uk/gallery/IMG_2129b.jpg
http://www.locostbuilders.co.uk/gallery/aIMG_2470.jpg
http://www.locostbuilders.co.uk/gallery/IMG_2089b.jpg
http://www.locostbuilders.co.uk/gallery/IMG_2092b.jpg
http://www.locostbuilders.co.uk/gallery/IMG_2045b.jpg
TimC
posted on 23/7/11 at 07:33 AM |
How is this not sold yet?
Wheels244
posted on 4/8/11 at 10:07 AM |
U2U sent.
Very interested.
Shandylegs
posted on 11/8/11 at 01:57 PM |
Having trouble getting hold of Ned via U2U. If only to put me out of my misery, can anyone confirm that the car has been sold?
ned
posted on 15/8/11 at 03:33 PM |
Car still available, u2u's responded..
Thanks,
Andrew.
ned
posted on 19/9/11 at 06:07 PM |
Car now sold
zilspeed
posted on 19/9/11 at 06:18 PM |
quote: Originally posted by ned
Car now sold
Sad to hear that.
At least you'll have a few pennies in your pocket.
Any plans for the future ?
It needn't be a kit car if you can't bring yourself to go there again.
Mr G
posted on 19/9/11 at 06:23 PM |
Wheels244
posted on 19/9/11 at 07:44 PM |
Don't be sad everyone - it's gone to a good home ---- ME !!
I've got big plans for it - watch this space
