Author: Subject: 2.0xe trigger wheel advice
nige
posted on 2/8/11 at 07:51 AM Reply With Quote
im in need of a trigger wheel for my red top
anyone have experiance or have fitted one
pics and info would be a great help
cheers nige
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
ned
posted on 2/8/11 at 08:02 AM Reply With Quote
what do you need to know? you bolt it to the crank, I'd use some thread locking stuff.
beware, I've got yellow skin
nige
posted on 2/8/11 at 08:30 AM Reply With Quote
do you have a pic
onto the face of the crank pulley with the main bolt ???
Hector.Brocklebank
posted on 2/8/11 at 08:53 AM Reply With Quote
Cant you use the XE's own internal 60-2 trigger ?
nige
posted on 2/8/11 at 09:14 AM Reply With Quote
ive not done one before and have no experiance of these
where is it , and will i be able to use it with my megajolt
anymore info would be gratefully received
also a picture would be of great help
blakep82
posted on 2/8/11 at 09:59 AM Reply With Quote
for megajolt it has to be a 36-1 wheel, which is annoying. i'm still trying to do the one on my xev, i'm finding quite a pain personally, i can't get it to spin centrally.
have a look at my thread from last nite
http://www.locostbuilders.co.uk/viewthread.php?tid=158998
________________________
nige
posted on 2/8/11 at 10:16 AM Reply With Quote
this sounds like another problem area
hope there is a solution
has anyone else fitted a trigger wheel to an xe
blakep82
posted on 2/8/11 at 10:23 AM Reply With Quote
in theory the fitting should really be the same sort of process as any engine, most people seem to manage alright, all i'm saying is that I'M having problems.
have a look on the autosportlabs website (who design the megajolt) for fitting ideas. it shouldn't really be too difficult, i think it comes down to the amount of space i have in my car, and my level of attention to detail, which is sometimes low for this sort of thing lol
http://www.autosportlabs.net/Trigger_Wheel_Designs
and
http://www.autosportlabs.org/viewforum.php?f=3
its worth it when it works though!
looks like omega 24 v6 has fitted one to a xe
[Edited on 2/8/11 by blakep82]
nige
posted on 2/8/11 at 10:32 AM Reply With Quote
i see that from the pics it is welded
i will have to remove my crank pulley
and see if i can get it machined , to take one
and weld it
thanks for that
ned
posted on 2/8/11 at 10:42 AM Reply With Quote
I use the standard internal one on the crank, looks like this:
pistons and rods in
pistons and rods in
Hector.Brocklebank
posted on 2/8/11 at 02:29 PM Reply With Quote
A.F.A.I.K. he is running the stock 60-2 internal trigger wheel witha Megasquirt setup.
blakep82
posted on 2/8/11 at 02:38 PM Reply With Quote
Yeah I seen that after
Hector.Brocklebank
posted on 2/8/11 at 04:56 PM Reply With Quote
Teachers head on..... Yes, "I saw" that after "I posted"...
