New Topic New Reply
Author: Subject: Will 13" Caterham R500 Wheels fit my indy r?
Iaing
posted on 17/10/11 at 11:59 AM Reply With Quote
Does anyone know if R500 wheels will fit on the sierra hubs on my Indy R? I've got a set of the high spec calipers on the front and standard disks on the back.
Iain
Mk Indy R - Hayabusa Power
ajw
posted on 19/10/11 at 08:22 PM Reply With Quote
wheels
try compomotive cxr. I am using 7in front and 9in rear
T66
posted on 19/10/11 at 09:01 PM Reply With Quote
arent cxrs the ones fitted to r500s ?
My Fiat has borrowed Caterham wheels at the minute, cannot recall if they were r400 or r500s..
Iaing
posted on 20/10/11 at 09:19 AM Reply With Quote
Thanks for the replies, I knew someone would know
adampage
posted on 21/10/11 at 03:05 PM Reply With Quote
I don't think so
Caterham make their own 8-spoke 13" and 10-spoke 15" wheels, and I'm pretty sure they're not CXRs.
They look different anyway, the spokes on the Caterham are straight, curved on CXRs aren't they?
As to fitting on the indy, I think some people struggle with the rear calipers with handbrake spring sticking out & fouling.
Ad
daniel mason
posted on 21/10/11 at 03:26 PM Reply With Quote
I got them on my mnr with a shortened spring. And they are very light.
Iaing
posted on 21/10/11 at 10:15 PM Reply With Quote
Is shortening the spring easy to do?
hobbsy
posted on 21/10/11 at 10:50 PM Reply With Quote
Depends which r500. Some are Mike Barnby magnesium split rims. Very light (ive had a couple of sets) but need crack testing yearly tobe safe.
gingerprince
posted on 22/10/11 at 08:48 AM Reply With Quote
Regardless of brake clearance issues, don't cateringvans run different offset, so on a sierra donor based kit the wheels will stick out wider than they should?
New Topic New Reply
