New Topic New Reply
Author: Subject: Transporting Indy R inside a van?
Iaing
posted on 22/11/11 at 02:44 PM Reply With Quote
Has anyone tried to transport their MK in a van? Looking at the sprinter dimensions i think it might fit in the back of one of those!?
Getting desperate as I need to get the car down to MK on Friday.
Iain
Mk Indy R - Hayabusa Power
afj
posted on 22/11/11 at 02:54 PM Reply With Quote
chassis will fit but the whole car with wheels wont im sure there is a picture somewhere of a indy in the back of a van at a funny angle
eerrrrrrrrrrrrrrrr
vinny1275
posted on 22/11/11 at 02:57 PM Reply With Quote
I've not done it, but here are a couple of things to consider -
what's the size between the wheelarches like? Don't forget that they intrude into the load space, and you'll either need to go between or over them.
Are the tie-down points inside the van strong enough to take the weight of the car trying to break free if you have an accident?
Can you get long enough ramps to actually get the car in the back (especially if you have to go over the van wheelarches?
HTH
Vince
MK9R
Rent a luton or tipper with a tail lift
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Iaing
posted on 22/11/11 at 03:07 PM Reply With Quote
Thought about a Luton but will it fit on the rear lift?
MK9R
posted on 22/11/11 at 03:10 PM Reply With Quote
You'd have to clamp an extension on, and probably give it a helping hand. Or just get some long ramps
Cheers Austen
RGB car number 9
www.trackace.co.uk
designer
posted on 22/11/11 at 03:37 PM Reply With Quote
if you told us where you are it would help!
Tiger Super Six
posted on 22/11/11 at 05:48 PM Reply With Quote
Went to a Caterham accademy race last year and a guy used a van to move his race car around, so in theory it is do-able, subject to dimensions of your car compared to the Caterham and also I don't know how he strapped it down (he may have welded some points in?).
Not sure that really helps
Mark
Tiger Avon
Iaing
posted on 22/11/11 at 05:54 PM Reply With Quote
Strange, posted a reply and it hasn't appeared.
Anyway problem solved, getting a reanult van silimar to a luton and will sus out a ramp to roll it in. Apparently its only about 2.5 ft off the ground at the back so shouldn't be too difficult to make up a ramp.
Iain
fullpint
posted on 22/11/11 at 07:49 PM Reply With Quote
Rent a trailer? I expect it's cheaper than van hire!!!
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
daviep
posted on 22/11/11 at 09:05 PM Reply With Quote
We used to transport a Global GT Light race car inside an Iveco Daily, was a bit of a squeeze and we made a set of ramps inside the van so that the car sat at quite a steep angle both for length and to avoid the wheel arches.
Might be a good idea to get the van a couple of days before you need it to make sure you can get it in, I'm guessig it must have the wheel arches in the load space as anything above the wheel will be higher than 2.5 feet. Also I think you may be suprised at how long your ramps need to be even to go up 2.5 feet.
Davie
New Topic New Reply
